Posts837,969
Posts: 6,675 Likes: 441
Posts: 6,675 Likes: 441 |
I went for the Magnecor - can't remember where I got them from, but again, fitted fine, straight out the box. Possibly Burton? ![[Linked Image]](https://www.tm-img.com/images/2020/05/09/96_Tyyj1AYgtumDLigl5zUKtNuuv9XZ51-K8dP9qfXMGHJsx5OPHyprjUwgnQXBq3bXY3vnpawHf83gCWPcpEy_B_TsS5a-9cL7vbPKgXahVZ8A43T_yPgc__jxp4a4MdztuNn1UIuui77c6L6l8pgvsD5SQazE319tdrNe_52LwQSt9Nor8qHC7BqHXw2eXc6HkZcFR.md.jpg) Looks very neat with those spacers  Thank you - cheap generic ally ones from eBay.
Posts: 2,310 Likes: 5
Posts: 2,310 Likes: 5 |
Cain sells them on his website and they fit straight out the box..Wolf Performance.
Posts: 287 Likes: 8
Posts: 287 Likes: 8 |
![[Linked Image]](https://www.tm-img.com/images/2020/10/21/Magnicor.png) I am very happy with the fit of the Magnecor leads on my Twin Cam, no problems in fitting and they were supplied by DC Performance Magnecor Leads
Owen "bilibib" 1982 4/4 Twin Cam, Royal Ivory 1932 Super Sports, Duo tone(two tone)Green
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
Ok, If I swapped these factory leads on my Sigma engine for the Magnecor leads, would I notice any extra horses ? ![[Linked Image]](https://www.tm-img.com/images/2020/04/24/D97D808E-2540-406C-ACD5-1A8C5B233F85.jpg)
Craig Jezz
Posts: 902 |
I don't think you'd notice on a road car unless the existing leads were old and deteriorating. I know you like red bits on your car however Craig and red leads would look good with your engine plaques
Rob
Posts: 534 Likes: 1
Posts: 534 Likes: 1 |
I have a set I took off my Plus 8. Happy to consider splitting them if I have the right lengths for a 4 pot.
Posts: 318 Likes: 5
Posts: 318 Likes: 5 |
What is the normal distributor fitting for the leads of the 1600 crossflow. Inline or 90*?
What is the normal distributor fitting for the leads of the 1600 crossflow. Inline or 90*? Mine are inline.
Posts: 9,552 Likes: 134
Posts: 9,552 Likes: 134 |
I don’t think the leads will give a noticeable ( if any) performance hike. They should help get a good consistent spark though, helping get a decent burn. Years ago I had an XR3i and it developed a bad misfire from about 2000rpm. New leads cured it. Standard leads not Magnecor. Two weeks ago I checked my plugs and leads on the Plus8 as an annual job. MOT looming! The leads at least 8 years old.
Posts: 318 Likes: 5
I'm changing mine because one of the leads has a higher resistance than it ought to. I didn't think the overall resistance was an issue until I read an article recently which explained how the spark worked. It needs volts to make the spark but current to maintain it, so if leads are too high resistance the spark will be weak because of less current flow. As I've been having a misfire on one of the cylinders this kind of makes sense. I'm hoping the new leads will sort that.
I'm getting my leads from Mr Retro Leads. Anthony is very helpful. I found a phone call was better than email. He'll build them to whatever design you want. Just ask.
