10 members (JohnHarris, B3MOG, mph, Whizjet, Alistair, chanteclair, James B W, Julian BB, Wouter, bmgermany),
197
35
Topics49,901
Posts838,042
Posts: 296 Likes: 3
Posts: 296 Likes: 3 |
LED bulbs would the safest solution in that case, and you can ignore the CAN bus concerns of some applications.
2020 M3W
Posts: 8,697 Likes: 416
Posts: 8,697 Likes: 416 |
High Robbie, yes ,thanks for the reply. I have a set of billet ally lights that i bought to replace the cheap plastic front indicators. These lights are fitted with typical lamps for this function.
I was just unsure if replacing led lamps with incandescent lamps would cause a problem, thats why i want change them for led`s. If these lamps have the BA15s holders you refer to, LED's with the same fitting are available and recommended. Classic Car LED's will supply anything you need.
Posts: 504 Likes: 2
Posts: 504 Likes: 2 |
I was just unsure if replacing led lamps with incandescent lamps would cause a problem, thats why i want change them for led`s. Indicators? If you by this mean direction indicators,you can change to LED, but beware of the hyperflash issue. If you mean side markers with a stable, non-flash light, LED should work fine.
Robbie the Norseman 2004 V6 Roadster Sherwood green
I was just unsure if replacing led lamps with incandescent lamps would cause a problem, thats why i want change them for led`s. Indicators? If you by this mean direction indicators,you can change to LED, but beware of the hyperflash issue. If you mean side markers with a stable, non-flash light, LED should work fine. Robbie the M3W has LED indicators as OE as you have already acknowledged, so replacing like for like won't be an issue.
Posts: 504 Likes: 2
I was just unsure if replacing led lamps with incandescent lamps would cause a problem, thats why i want change them for led`s. Indicators? If you by this mean direction indicators,you can change to LED, but beware of the hyperflash issue. If you mean side markers with a stable, non-flash light, LED should work fine. Robbie the M3W has LED indicators as OE as you have already acknowledged, so replacing like for like won't be an issue. Yes, we agree on that, but it seems that TS has taken away the OE ones and replaced them with somethinghe nicer. Being a little blond, I have not understood what is wanted taken out and what is wanted put in, depending of his new light..... Anyway, LED and incandescent bulbs are interchangeable so he can do what he wants without worries, as long he avoids the direction indicator LED hyperflash issue and does not put a coloured LED behind a tinted glass. Cheers, gentlemen!
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
The flasher unit is LED only, standard bulbs will probably blow it.
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
I have standard bulbs used in parallel with the oem led lamps. ![[Linked Image]](https://www.tm-img.com/images/2019/10/01/IMG_0395.jpg) Standard incandescent bulbs for a year without problem.
Posts: 902 |
Thanks guys, i should have said at the beginning that i was swapping out or adding extra indicator units. Led lightsI would never have thought of this. Thanks for your input.
Apart from the headlights, all the light bulbs in the three-wheeler are LED from the factory (in mine at least), so I assume this is in fact a headlight question.
Rockabilly John - are you asking about the marker/side-light bulbs in the European headlamps? (The US ones don't have these)
All the lamps EXCEPT the Headlamps are indeed LED, so I changed the headlamps to LED BULBS. Wow, what a difference. I intentionally left one lamp stock to show the difference before I changed it too. ![[Linked Image]](https://www.tm-img.com/images/2022/02/03/LowBeam.jpg) Low Beams ![[Linked Image]](https://www.tm-img.com/images/2022/02/03/HighBeam.jpg) High Beams
Posts: 101 |
Very cool. Which bulbs did you use? Any glare issue for oncoming traffic.
Scott
2018 M3W 1995 Porsche 993
