8 members (John Wilcox, Plus Four Guy, Arwyn Williams, gomog, AlyMatt, jbk, Sir Percival, TalkMorgan), 229 guests, and 31 robots.
+8Rich 96
John V6 51
Topics49,901
Posts838,046
LED bulbs would the safest solution in that case, and you can ignore the CAN bus concerns of some applications.
2020 M3W
Originally Posted by rockabilly john
High Robbie, yes ,thanks for the reply.
I have a set of billet ally lights that i bought to replace the cheap plastic front indicators.
These lights are fitted with typical lamps for this function.
I was just unsure if replacing led lamps with incandescent lamps would cause a problem, thats why i want change them for led`s.
If these lamps have the BA15s holders you refer to, LED's with the same fitting are available and recommended. Classic Car LED's will supply anything you need.
Indicators? If you by this mean direction indicators,you can change to LED, but beware of the hyperflash issue. If you mean side markers with a stable, non-flash light, LED should work fine.
Robbie the Norseman
2004 V6 Roadster
Sherwood green
Robbie the M3W has LED indicators as OE as you have already acknowledged, so replacing like for like won't be an issue.
Yes, we agree on that, but it seems that TS has taken away the OE ones and replaced them with somethinghe nicer. Being a little blond, I have not understood what is wanted taken out and what is wanted put in, depending of his new light..... Anyway, LED and incandescent bulbs are interchangeable so he can do what he wants without worries, as long he avoids the direction indicator LED hyperflash issue and does not put a coloured LED behind a tinted glass.
Cheers, gentlemen!
Robbie the Norseman
2004 V6 Roadster
Sherwood green
The flasher unit is LED only, standard bulbs will probably blow it.
I have standard bulbs used in parallel with the oem led lamps.
Standard incandescent bulbs for a year without problem.
Thanks guys, i should have said at the beginning that i was swapping out or adding extra indicator units.
Led lights
I would never have thought of this.
Thanks for your input.
JohnMat #732163 03/02/22 09:33 PM
Originally Posted by JohnMat
Apart from the headlights, all the light bulbs in the three-wheeler are LED from the factory (in mine at least), so I assume this is in fact a headlight question.
Rockabilly John - are you asking about the marker/side-light bulbs in the European headlamps? (The US ones don't have these)
All the lamps EXCEPT the Headlamps are indeed LED, so I changed the headlamps to LED BULBS. Wow, what a difference. I intentionally left one lamp stock to show the difference before I changed it too.
Low Beams
High Beams
Very cool. Which bulbs did you use? Any glare issue for oncoming traffic.
Scott
2018 M3W
1995 Porsche 993
