6 members (John V6, RichardV6, Plus Four Guy, sprinty, Rastus, Morganmike), 114 guests, and 38 robots.
+8Rich 101
John V6 57
Topics49,911
Posts838,153
Georgetoad, woolfie
Fus969 Offline OP
Thanks for the reply’s I’ll give it a go next weekend at my garage inn another job is to keep the fridge stocked up till the pubs reopen again , it’s so busy here in Macc forest I can’t get the car out because of the traffic and I thought we were in lockdown?
Windscreen washer bottles and pumps are available on ebay - typically between £12 and £20 - I did buy one for 'stock' a few years ago. The problem I had on our shopping car was that the sludge resulted in a stalled rear screen pump and it took me an hour or more to clear it and get it working again.
Mike Smith
2007 +4
Fus969 Offline OP
Almost embarrassed that I asked this question I took the washer bottle out ( very easy ) took the pump off ( very easy ) tested the pump which is working ( I impressed myself there as electrics aren’t my strong point ) now all I have to do is find the fuse and check that ! . It’s annoying because I can build houses but anything electrical on a car and I’m stumped
The fuse box is under the dash above the gearbox tunnel.
See Gomog
fuses
These washer/wiper switches are prone to failure just in case it's not the fuse.
Switch
Fus969 Offline OP
Just cleaned a few bits then talked to it nicely and it self repaired! Great cars these Morgan’s
