Topics49,912
Posts838,163
Posts: 59 Likes: 1
Posts: 59 Likes: 1 |
Thanks for the reply’s I’ll give it a go next weekend at my garage inn another job is to keep the fridge stocked up till the pubs reopen again , it’s so busy here in Macc forest I can’t get the car out because of the traffic and I thought we were in lockdown?
Posts: 322 Likes: 3
Posts: 322 Likes: 3 |
Windscreen washer bottles and pumps are available on ebay - typically between £12 and £20 - I did buy one for 'stock' a few years ago. The problem I had on our shopping car was that the sludge resulted in a stalled rear screen pump and it took me an hour or more to clear it and get it working again.
--------------------------- Mike Smith
2007 +4
Posts: 59 Likes: 1
Almost embarrassed that I asked this question I took the washer bottle out ( very easy ) took the pump off ( very easy ) tested the pump which is working ( I impressed myself there as electrics aren’t my strong point ) now all I have to do is find the fuse and check that ! . It’s annoying because I can build houses but anything electrical on a car and I’m stumped
Posts: 27,848 Likes: 765
Posts: 27,848 Likes: 765 |
The fuse box is under the dash above the gearbox tunnel. See Gomog fuses
Posts: 37,489 Likes: 993
Posts: 37,489 Likes: 993 |
These washer/wiper switches are prone to failure just in case it's not the fuse. Switch
Posts: 59 Likes: 1
Just cleaned a few bits then talked to it nicely and it self repaired! Great cars these Morgan’s
