0 members (), 189 guests, and 39 robots.
+8Rich 101
John V6 57
Topics49,911
Posts838,152
Georgetoad, woolfie
#671885 09/11/20 07:19 PM
Fus969 Offline OP
This subject has probably been covered many times but I’m curious as to the advantage of an upgrade to the air filter mine has the standard trumpet intake and I’ve read that a K&N filter is better . Any advice on this would be appreciated also does it affect the sensor if you fit a different filter? Mines a 3.9 ,97 +8
Fus969 #671894 09/11/20 08:18 PM
Sir S1'a'lot
Sir S1'a'lot
There are a few threads on this very recently.
I’ve just ordered a cone filter for mine. Will collect it tomorrow
2002 Aero 8 S1
2023 Plus 4 (woman’s)
Fus969 #671922 10/11/20 08:06 AM
Andy G
1999 +8 , Indigo Blue.
Fus969 #671939 10/11/20 10:13 AM
I fitted an ITG foam filter many moons ago, this resulted in discarding the old filter housing & fabricating a new support fram for the Air Flow Meter. If you decide to take this path, it's very important to ensure there is no Earth path between the Airflow Meter & the car body
Cheers
1999 Morgan Plus 8. 3.9 ....
1961 Alvis TD21 Series1 3 Litre Auto....
Sir S1'a'lot
Sir S1'a'lot
Thanks Smudger.
I’ve just this minute bought an itg. Plan was to cut the support off the old airbox and use this.
2002 Aero 8 S1
Originally Posted by MOG 615
Do you have a part number please for the JR filter you fitted please? There’s no mention of Morgan on their website. Did you ditch the entire original filter housing?
Mike H
Bourgogne Franche Comté
Viper #679998 26/12/20 05:38 PM
Originally Posted by Viper
Thanks Smudger.
Did you get the new filter fitted OK? I’d like to do the same to mine - which ITG did you get?
Mike H
Sir S1'a'lot
Sir S1'a'lot
Thanks Smudger.
Yes I did. Bought it from BHM.
Had to cut to take-off from the existing filter housing where it mounts to the air flow sensor.
2002 Aero 8 S1
Viper #680152 27/12/20 10:04 PM
Thanks Smudger.
Thank you!
Mike H
