8 members (GrumpyPa, Rog G, RichardV6, Laurens, Craig Jezz, JMcL, Carbuilder, Ricosan), 321 guests, and 47 robots.
+8Rich 103
John V6 63
Suspension upgrades
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,918
Posts838,244
MossyfromNZ
#671751 08/11/20 10:25 PM
Whilst “playing “ with the hood I managed to pull out the center stud around the front wind screen ....it came out in the hood fixation leaving an empty hole in the top of the wind screen! Anyone had this? Anyone know how to repair it? Thanks for any ideas. Best wishes
Hi Rutter sells them.looking at the photo on their site it is held on by a bolt.
https://mogparts.net/product/lift-a-dot-stud-2ba-thread-windscreen-frame
Online NoMood
If the nut is lost maybe a 2BA rivnut would work.
Remove the windscreen, undo the 2 screws each side holding the frame together (note the lengths - one is longer than the other), separate the frame and slide the glass out. This will give you access to the inside of the frame to fit a new stud.
Do it on a padded surface so as not to risk damaging the glass, and use plenty of soapy lube when reassembling.
When I did mine it was pretty manky inside and I ended up having to make some new brass blocks for the frame screws to go into but apart from that it was pretty straightforward. But then my car was over 20 years old at the time and had a pretty hard life. If your car is younger and better cared for then it shouldn't be a problem.
Europaspares sell the studs - maybe cheaper than uncle Melvin. Worth checking.
Thank you all very much for your helpful comments and advice. Much appreciated.
Andrew
Ray Offline
Cheap try ,araldite it back in. Never heard of this happening before.
