5 members (CooperMan, JohnHarris, yrr13, TeddyAds, MJF), 226 guests, and 24 robots.
+8Rich 91
John V6 49
Posts837,982
RJW #672389 13/11/20 11:14 AM
TBM Offline
I'm running 205 on a 5.5 rim. No issues.
6.5 is recommend, but 5.5 to 7.5 is acceptable.
RJW #672400 13/11/20 12:10 PM
Any new modern tyre will have a better road grip than a 7 year old rubber
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
RJW #672407 13/11/20 12:55 PM
Ray Offline
The main thing to look at is the clearance between the top of the tire and the crosshead. Many years ago I lost two new tires by not checking.
sospan #672419 13/11/20 03:52 PM
Originally Posted by sospan
Sizes are the same, both 15” and 60 profile so there shouldn’t be any speedometer issues.
Sorry, but beg to disagree. The 60 is the aspect ratio of the tyre which is the percentage of width to give height of tyre. So as the width is increased, so too is the overall diameter, even though rim size and aspect ratio are the same.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
RJW #672421 13/11/20 04:01 PM
A change to wider tyres ought to have a reason (as any change....)
Grip: most likely better in the dry, worse in the wet. And as said here, anything new will be better than your existing tyres.
Handling: heavier in all conditions, but specially going slow and above all when parking etc.
Looks: a wide tyre might give a mean, racy look, but will not be in harmony with the car's classic appearance (IMHO).
Fuel consumpition: somewhat higher, but might be negligible in a Morgan with low mileage.
Beware of conflict with chassis, wheelarc, stays etc.
I have 205/55/16 om my Roadster, as original. Optically it looks nice and correct with the wider wings, but they do give a heavy handling when going slow.
My preference with the neat 4/4 would be to stick to the original 195 and use the possible difference in price to something else use- and beautiful (some good mirrors for instance....)
Robbie the Norseman
2004 V6 Roadster
Sherwood green
Mark+4 #672427 13/11/20 04:48 PM
Originally Posted by Mark666
One benefit will be that the tyre extends out further from the rim, so the wheel is better protected if you catch a curb.
Some premium manufacturers make a specific 'rim protector' spec in most sizes (has a sort of lip in the sidewall) you just have to check what their order code is & check the tyre monkeys order the correct ones
Michelin, Continental & Pirelli, certainly do them
RJW #672438 13/11/20 05:21 PM
TBM Offline
I was surprised about the handlng of mine. With the 165 tyres I found the steering a little heavy and ran at about 26psi to try and lighten it up. I was expecting it to be far worse with the 195 front, 205 rear set up, but actually found it lighter, and run at a much lower psi (about 22 I think).
Styling is obviously a very personal thing - I'm a fan of the 'big tyre' and thought the original pram wheels spoiled the look of my old 4/4.
Can't say I've noticed any detriment to the handling, but I tend to bimble rather than hoon around.
Deejay #672444 13/11/20 05:36 PM
Agreed. When the stainless 7 x 16" rims were spec'd on the Roadsters instead of standard 15", they dropped the tyre aspect ratio from 60 to 55% to compensate and so maintain similar circumference.
Deejay #672468 13/11/20 07:11 PM
Oops! Yes. Brain fade.
Did the calc and 6mm difference in section height.
RJW #672487 13/11/20 08:42 PM
IMHO wider tyres serve no purpose on the Plus 4. It is quite probable that you will get reduced grip on dirty or wet surfaces, steering will probably be heavier (that is why so many Roadster owners opted for power assisted steering. Also it is possible that the tyres could be outside the mudguards. Is that an MOT failure in the UK? I doubt mudguard extensions are available for the Morgan laugh
I have fitted 195/65 15 tyres to get better ground clearance. if you want better grip just get the correct tyre size in a good sports compound.
Regarding Speedo calibration you may find no change is required because the standard setup under reads the speed and distance. You can calibrate the speedo after travelling an accurately signed distance (say 10 miles) and compare that to the odometer distance. Calibration is not difficult and instructions can be found on the Smith's website
