Posts837,985
Posts: 5,017 Likes: 3
Posts: 5,017 Likes: 3 |
I changed narrow tyres to wider tyres and later back to the narrow version again. For my experience the narrow ones are the better option and fit perfect to the driving characteristics of the 4/4. Most likely the +4 will give you a similar feedback.
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
The +4 is nimble and chuckable, the wider tyres will possibly hang on for longer BUT when they go you will be travelling at higher speed and catching them will be that bit more tricky. I think it was Tim (Hamwich) who said you want to choose tyres which you can break traction at low speeds to have fun, and will be controllable when drifting at higher speeds. Wider tyres won't help in either respect.
The 205/60 x 15 is a standard size for the alloy wheeled +8 , and I think that it over-tyred, a +4 needs a narrower contact patch to maintain its handling.
I did indeed say this, I am firmly in the camp that says that on a Morgan one should go for the narrowest, tallest profile tyres one can fit in order to maintain lightness, agility and fun factor, bu tI acknowledge that many may prefer a more sedate 'planted' feel on the road - in which case the critical factors would be clearance and wing width, as others have pointed out. My 4/4 has 165bhp, weighs around 860kg, and is perfectly happy on 165 section tyres. A 2013 Plus 4 produces less power but has a wider stance and so is probably better on the 195 tyres but I can't see that going to 205 section would be a good idea unless one really really liked the look and was happy to sacrifice a deal of handling performance to get it.
Posts: 1,246 Likes: 30
Posts: 1,246 Likes: 30 |
My 4/4 is on 175/70 R15. Which are a good compromise, from standard. Much wider would be too much. For a +4 maybe see if there is an equivalent size increase available.
Posts: 27,835 Likes: 759
Posts: 27,835 Likes: 759 |
I can confirm the 205s make the low speed steering very heavy on a Roadster without power steering, especially at low speed.
Posts: 7,435 Likes: 122
Posts: 7,435 Likes: 122 |
ca. 9 : 2,5 against wider tyres so far, but all much nicer to read than just having this numbers
Posts: 313 Likes: 1
Posts: 313 Likes: 1 |
Many thanks for your replies to my question. I must say that every aspect of the suggested change to wider tyres has been covered in detail, this really is a great resource. One important aspect that I had not considered is the possibility of heavier steering at parking speeds. It’s heavy already on the 195 wide tyres and I wouldn’t want to make it any heavier. Another downside is the possible adverse change in handling. I’m pleased with the way the car handles at present and don’t want to spoil it. So, on balance, I’ll stay with the standard size tyres (195-60-15) when I change in the near future. Thanks again. Bob.
Posts: 9,552 Likes: 134
Posts: 9,552 Likes: 134 |
For me it is tyre grip that is the main criteria. Especially wet grip. The small contact patch between the car and road is a big safety factor. Other factors that come after this are a combination. Tyre pressure that gives preferred feel, ground clearance (especially for aluminium sumps!), tread wear, cost, looks. Yes, the wider tyres make steering heavier when parking but as soon as you get some speed they feel fine. You can play with limits for steering wheel size and material to help, I changed from a thin wooden to same diameter but fatter leather Moto Lita. Keeping the kingpins greased is another. Power steering upgrade would be nice but I’d spend that money on ABS for braking. If the weight of the steering becomes an issue I could add power steering. (Change the car even). There is some good input here by those with experience of Plus4 characteristics. Why re-invent the wheel ! Pun intended.
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
I have found over the years that wide tyres and no weight in the rear can lead to some very twitchy times in the rain. I had couple of XKR's a few years ago and they were very prone to losing traction.... I drive my +8 very gingerly in wet weather.
+8 4.8
