6 members (RichardV6, JohnHarris, RickyH, banbury, Image, Rastus), 244 guests, and 27 robots.
+8Rich 99
Luddite 54
Topics49,905
Posts838,098
Page 2 of 4 1 2 3 4
Ray Offline
Originally Posted by xc68anc
After the experience with aluminum building an enginecover and the hoodstay I want to go further.
Building a tooltray. Reading so much as possible I want to do it as a DIY.
Not only I read about the 1.5mm is the maximum for a DIY, I just noticed it in the real world.
So the question: how do you bend the sheets in your garage or at home?
And the total other way: I wonder about the british expierence about/ around Kitharas and glassfibre is there someone
who has build a glassfibre tooltray?
René
. Thinking of just using the underneath of the original tray as a moulding for a layer of fiber glass and plenty of resin, should work.
For some reason I don't gel with fibreglass.
X
xc68anc Offline OP
X
Hello Dave,
that‘s the point - why? Is it a forgotten craftsmanship?
René
2018 plus4 (sports green)
I've just completed the fibreglassing of the cabin top of my boatbuild. I did the hull a couple of years ago.
It's time consuming, messy, you have to be very organized material wise because of the limited time you have to work with the resin and it's a significant health hazard. Exposure to the resin and cloth/matting can cause serious health damage!!
It's been my least favourite part of the build, closely followed by the painting using a two pack system.
That said, it can produce good results but I made my tool tray from plywood.
And by the way Dave, your subtle humour didn't go unnoticed laugh2
Gordon Duguid
I'm in the wooden tool tray camp, not only because compared to the other options it's quick and easy requiring no special tools or skills, but also because as it integrates with the body frame, wood seems to me to be the most appropriate solution.
My first tray was wood and it does the job.
My second tray was based on a single piece of aluminium in a gentle curve, with sides and diff cover added. That was a tough challenge.
So my third tray was made of sections. One each side with a centre section. This method works well.
Wood also seems to be a better sound dampener.
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
As SimonH says the grade of Ali is key. There are different grades for different end use, from simple noncritical use to more exotic alloys, particularly the aerospace grades. Some are age hardening due to deliberate alloying composition, as with all metals, not just Ali.
Brings back memories of my days as a Metallurgist.
X
xc68anc Offline OP
X
Some days ago, in my area a lot of good days out in the MOG.
Today I start a new try.
At first: heating wasn‘t my thing. German fear. I‘m afraid about overheating.
So the simple way: brute. No secco.
To do it Brut there are different ways. At first I start with a piece of wood 20mm thick and 150 to 300mm with a 500gramm hammer.
Works. But not in my sence.
After some time of frustrating beats I change over to a massive blog of wood 50x50mm and 300mm long and a 1000gramm hammer.That was a massive step forward. Works.
So with this knowledge I fished the first bended sheet.
Next step - you will see.
René
Online NoMood
I guess I'm fortunate in knowing a local old school guy that rebuilds Classics. He works on a shoe string and buys up old machinery as required. One such purchase was an electric sheet press. It had no difficulty putting sharp bends in 3mm sheet steel for a small job on my Land Rover. It wouldn't even notice 2mm ally.
Page 2 of 4 1 2 3 4
