1 members (GLLOQ),
209
32
Topics49,897
Posts838,018
Posts: 121 Likes: 1
Posts: 121 Likes: 1 |
I ordered the third brake light and it is on its way. They are extremely proud of their parts but I decided to just buy the set up. Anyway, is there enough wire to reach the area that it needs to plug into the third brake light. I took a quick peak at it and it doesn't appear to have enough wire to reach to the top of the car where the light will mount.
Posts: 8,696 Likes: 416
Posts: 8,696 Likes: 416 |
If its a factory item, I would be very surprised if it doesn't have a lead long enough, terminating in an AMP Econoseal two way plug, to reach matching socket on loom.
ETA: you may have to assemble the supplied connector after fitting lamp to car.
Posts: 1,738 Likes: 56
Posts: 1,738 Likes: 56 |
My factory item came with rather short leads. Idealy I guess the leads should be around 75cm long to reach the loom connector adjacent to the fuel pump. ![[Linked Image]](https://tm-img.com/images/2020/11/02/P1150339.jpg)
Andy
Whoops  , just spotted your picture Andy on OP's previous thread. If the loom socket doesn't have enough spare cable wrapped away to reach, I would be tempted to obtain fresh female pins and extend the cables to loom socket to reach the plug on lamp. AMP Econoseal connectors are readily available on eBay. ETA: Loom schematic does show only 15cm at best on that portion of loom eminating from convoluted cover
Posts: 121 Likes: 1
Whoops  , just spotted your picture Andy on OP's previous thread. If the loom socket doesn't have enough spare cable wrapped away to reach, I would be tempted to obtain fresh female pins and extend the cables to loom socket to reach the plug on lamp. AMP Econoseal connectors are readily available on eBay. ETA: Loom schematic does show only 15cm at best on that portion of loom eminating from convoluted cover  When this light made of "gold" arrives, I will cut into the loom and see if the wire is long enough to reach. I am hoping it is just wrapped up in there.
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
They way I did it cost very little and I documented it in this web site.
