7 members (Bilymog, JohnHarris, sprinty, verysideways, aerotaff, TalkMorgan, Bishmog),
201
44
Posts837,962
Posts: 2,119 Likes: 70
Posts: 2,119 Likes: 70 |
Near the oil filter is the oil pressure switch but I wonder what the second one is? ![[Linked Image]](https://www.tm-img.com/images/2020/12/22/Olfilter_beschr_800x600.jpg)
Posts: 412 Likes: 10
Posts: 412 Likes: 10 |
Isn't one the oil pressure switch and the other for the pressure gauge?
2009 4/4 Sport in Red 2022 Harley Davidson FXLRS Low Rider S 1977 Triumph Stag
Posts: 37,473 Likes: 988
Posts: 37,473 Likes: 988 |
That's what I'd have thought too.
Posts: 8,695 Likes: 415
Posts: 8,695 Likes: 415 |
Similarl to the VDO sensors I fitted to a Guzzi special and as suggested above. A "T" adaptor allows both from the single pressure take off.
Posts: 28,909 Likes: 354
Posts: 28,909 Likes: 354 |
Did the same to my LR S11a to add an oil pressure gauge
Posts: 27,833 Likes: 758
Posts: 27,833 Likes: 758 |
As said one for the gauge one for the switch
Posts: 2,780 Likes: 5
Posts: 2,780 Likes: 5 |
Similarl to the VDO sensors I fitted to a Guzzi special and as suggested above. A "T" adaptor allows both from the single pressure take off. as i did to mine...not a good pic but shows the adaptor to enable both switch and gauge .. ![[Linked Image]](https://tm-img.com/images/2019/07/20/20190719_160735_resized.jpg)
Thank you for your comments! As you see on my picture there is only one switch connected.
Posts: 327 |
The large silver bit of kit is the pressure transmitter, depending on the number the range could be 0 to 10 bar or 0 to 7 bar. I'm told by Ian John at Caerbont that Morgan invariably specify the incorrect range. Not that that would matter too much as the accuracy is "heaven knows" Ian would not declare any accuracy saying the it was for "indication". I pulled one to pieces and its a lever moving a slidewire over a wire wound resistor, early 19th century technology but admirably suitable for the indicator that it sends its signal to. So don't pay too much attention to what it reads as far as accuracy is concerned. Can't quite see the other properly but its probably an RTD (resistance temperature detector) thats what i have installed there and it transmits to an oil temp gauge which i had Ian make for me. I also have an RTD installed in the ally Raceline sump as an optional monitoring point. Wish i could post a photo I'd post the calibration readings that i took.
