2 members (Tony Quinn, bmgermany), 331 guests, and 77 robots.
+8Rich 66
European Bike Week
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,881
Posts837,798
Page 3 of 3 1 2 3
Originally Posted by Bitsobrits
Interesting that it uses a returnless fuel system.
Where did you see that? It looked like the cross tube connector on the fuel injector towers. That is the same as MMC. I did not know that Big Dog used a cross feed system and would have thought an equal manifold system would have been better.
O
O
Looks returnless to me.
K Henry #679900 25/12/20 11:12 PM
Originally Posted by K Henry
It doesn’t, return line fitting on Fuel injector tower for the right cylinder (when oriented on M3W).
I don't see the return line. I think what you are seeing is either an injector or the pressure check fitting.
Late 2012 M3W
The cross feed line is what i see. Custom Morgan eliminates that cross feed line.
AZJowett #679931 26/12/20 10:27 AM
Originally Posted by AZJowett
If this engine was refurbished in 2013, it's a distinct possibility that it would need the cam chamber mods. i.e. Pinion pulley, tensioner, internal snap rings & cam pulley nuts. Also, I would guess that it has the original (prone to failure) rocker cover gaskets.
Andy
2Sharp #680013 26/12/20 07:57 PM
Originally Posted by 2Sharp
I would like to pick up a 132ci version. I guess I will call around.
Krazy Horse offers the 132 with all the associated upgrades (Stage 3, although they call it Stage 4) for between £9-10,000.
AZJowett #680992 01/01/21 11:11 PM
Seller is offering a 10% discount. Hmmm....
2018 S&S 110th Beetleback
1934 MX4 Beetleback (in restoration)
1965 Corvette Coupe 327/350
Page 3 of 3 1 2 3
