7 members (PaulJ, sewin, jbk, uvk33n, JohnHarris, Chris Cosher, TBM),
280
33
Topics49,913
Posts838,166
Posts: 59 Likes: 1
Posts: 59 Likes: 1 |
This subject has probably been covered many times but I’m curious as to the advantage of an upgrade to the air filter mine has the standard trumpet intake and I’ve read that a K&N filter is better . Any advice on this would be appreciated also does it affect the sensor if you fit a different filter? Mines a 3.9 ,97 +8
Posts: 2,050 Likes: 12
Sir S1'a'lot Talk Morgan Expert
Posts: 2,050 Likes: 12 |
There are a few threads on this very recently.
I’ve just ordered a cone filter for mine. Will collect it tomorrow
2002 Aero 8 S1 2023 Plus 4 (woman’s)
Posts: 2,272 Likes: 7
Posts: 2,272 Likes: 7 |
Posts: 238 Likes: 3
Posts: 238 Likes: 3 |
I fitted an ITG foam filter many moons ago, this resulted in discarding the old filter housing & fabricating a new support fram for the Air Flow Meter. If you decide to take this path, it's very important to ensure there is no Earth path between the Airflow Meter & the car body Cheers
1999 Morgan Plus 8. 3.9 .... 1961 Alvis TD21 Series1 3 Litre Auto....
Thanks Smudger.
I’ve just this minute bought an itg. Plan was to cut the support off the old airbox and use this.
Posts: 203 Likes: 8
Posts: 203 Likes: 8 |
Do you have a part number please for the JR filter you fitted please? There’s no mention of Morgan on their website. Did you ditch the entire original filter housing?
Mike H Bourgogne Franche Comté
Posts: 203 Likes: 8
Thanks Smudger.
I’ve just this minute bought an itg. Plan was to cut the support off the old airbox and use this. Did you get the new filter fitted OK? I’d like to do the same to mine - which ITG did you get?
Thanks Smudger.
I’ve just this minute bought an itg. Plan was to cut the support off the old airbox and use this. Did you get the new filter fitted OK? I’d like to do the same to mine - which ITG did you get? Yes I did. Bought it from BHM. Had to cut to take-off from the existing filter housing where it mounts to the air flow sensor.
Posts: 203 Likes: 8
Thanks Smudger.
I’ve just this minute bought an itg. Plan was to cut the support off the old airbox and use this. Did you get the new filter fitted OK? I’d like to do the same to mine - which ITG did you get? Yes I did. Bought it from BHM. Had to cut to take-off from the existing filter housing where it mounts to the air flow sensor. Thank you!
