Topics49,881
Posts837,797
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Interesting that it uses a returnless fuel system. Where did you see that? It looked like the cross tube connector on the fuel injector towers. That is the same as MMC. I did not know that Big Dog used a cross feed system and would have thought an equal manifold system would have been better.
Posts: 488 |
Posts: 807 Likes: 38
Posts: 807 Likes: 38 |
It doesn’t, return line fitting on Fuel injector tower for the right cylinder (when oriented on M3W). I don't see the return line. I think what you are seeing is either an injector or the pressure check fitting.
Steve Late 2012 M3W
The cross feed line is what i see. Custom Morgan eliminates that cross feed line.
Posts: 1,738 Likes: 56
Posts: 1,738 Likes: 56 |
If this engine was refurbished in 2013, it's a distinct possibility that it would need the cam chamber mods. i.e. Pinion pulley, tensioner, internal snap rings & cam pulley nuts. Also, I would guess that it has the original (prone to failure) rocker cover gaskets.
Andy
Posts: 1,031 Likes: 2
Posts: 1,031 Likes: 2 |
I would like to pick up a 132ci version. I guess I will call around. Krazy Horse offers the 132 with all the associated upgrades (Stage 3, although they call it Stage 4) for between £9-10,000.
Posts: 215 Likes: 6
Posts: 215 Likes: 6 |
Seller is offering a 10% discount. Hmmm....
2018 S&S 110th Beetleback 1934 MX4 Beetleback (in restoration) 1965 Corvette Coupe 327/350
