Posts837,997
Posts: 198 Likes: 1
Posts: 198 Likes: 1 |
I recall looking for the reflectors at the time I was checking out replacement lights and I believe they were Hella ones like these on Ebay but will double check size etc tomorrow when I go in the carcoon to visit for this week! https://www.ebay.co.uk/itm/HELLA-60mm-Round-Red-Rear-Reflector-/361517610144
Posts: 2,050 Likes: 12
Sir S1'a'lot Talk Morgan Expert
Posts: 2,050 Likes: 12 |
Yes they are about right though stick on not screw on. 60mm is correct
2002 Aero 8 S1 2023 Plus 4 (woman’s)
Posts: 198 Likes: 1
There are bolt on varieties available as well on a quick google search.
Posts: 198 Likes: 1
I take that back. Bolt on ones are 85mm or 41 and the 60s are all self adhesive.😡
Posts: 2,033 Likes: 23
Posts: 2,033 Likes: 23 |
Yes they are about right though stick on not screw on. 60mm is correct I take it the originals screw on? If so I will make a mental note so I don't suffer the same fate..
Aero 8 GTN #11
Well today I received my 2 indicators and two stop/tail lamps at £22 each.
They’re just the job and just need to change the wiring loom and lens but also need a couple of screws
Posts: 336 |
I could be wrong here, but those Local lamps look suspiciously like Land Rover Defender rears, certainly the fog lamp. My TVR uses the a landrover indicator on the front that I think is a rear indicator on the defender. might be worth looking at specialist LR sites for the odd Lucas spare ?
I could be wrong here, but those Local lamps look suspiciously like Land Rover Defender rears, certainly the fog lamp. My TVR uses the a landrover indicator on the front that I think is a rear indicator on the defender. might be worth looking at specialist LR sites for the odd Lucas spare ? They were used on many many British classics such as TR’s, Austin Healey etc etc. Maybe LR.
They’re just the job and just need to change the wiring loom and lens but also need a couple of screws I take it you will have to reuse your old lenses, a good polish and they will look new regardless. I was told to get some stainless replacement screws so let me know if you find any nice ones that aren't in a huge bulk buy quantity!
Aero 8 GTN #11
