Topics49,915
Posts838,210
Posts: 338 Likes: 1
Posts: 338 Likes: 1 |
The 2012 onward Morgan Three Wheeler (M3W) Registry
(use the number under the right seat and the VIN (the last 3 digits) and not the number of the wooden frame)
under VIN seat ------------------------------------------------------------ 0001 - xxxx - Feb '12 - Aeroman SOLD 0003 - xxxx - Feb '12 - Taffmog -original development car converted in 2013 to the Grim Reaper -UK 0004 - xxxx - Feb '12 - ajsms999 ex SGT DEMO 0006 - xxxx - Feb '12 - KJFB - ex Lifes DEMO 0007 - xxxx - Jan '12 - Melvyn Rutter Ltd - DEMO 0008 - xxxx - Jan '12 - Al1rhd 0009 - xxxx - Jan '12 - CSCC Sweden - DEMO 0013 - xxxx - Jan '12 - 1560 0020 - 2014 - Aug '12 - Thono Germany/Berlin - first registration in sweden ... 0027 - xxxx - Feb '12 - Tomtom 0032 - xxxx - Feb '12 - Herman01 0047 - xxxx - Feb '12 - Vitti4.3W 0049 - xxxx - Feb '12 - Asbojohn 0050 - xxxx - mar '13 - nadvys 0051 - 0051 - mar 12 Grimaud 0070-2011-March 2012 Chocadoodledoo, New Hybrid Chassis and Bodyshell( due to corrosion) in 2016. Plus Centa Drive, Comfort Kit,Urban Cooling Kit, Supermax Sprocket with modified early hub to give belt space. Nov 2019, Bleazey Driveline Conversion and crank oil seal mods. 0083 - 2048 _ Apr ,12 _ Elcyd 0109 - 2067 - Apr ,12 - Hugo ,Centa, chassis brace, comfort kit, rectifier, cam cover, cam bolts, new bearings ,steel sprocket, rear hub, 0125 - 1002 - May '12 - John Winn 0129 - 0092 - Apr '12 - JMD - new chassis/Centa/comfort kit 0130 - 0117 - Mar '12 - donaldosaurus - Convertisseur, Centa 0131 - 0083 - Apr '12 - P964 0133 - xxxx - May '12 - MTW69 0157 - xxxx - May '12 - CSCC Sweden ( ex Stig, now for sale) 0162 - 0107 - May '12 - MDH, (ex Ledgerwoods Demonstrator), Urban Cooling kit, Bonnet Latches, 12/14 Hybrid Chassis, Centa, Re-spray. New 2016 body. Steel drive pulley, Cambelt modification. Stainless cowling. 0189 - xxxx - June '12 - Robby Udine (Italy): upgraded wishbones, Blockley tyres, will have chassis bracing 0200 - 0141 - May '12 - Simmo 0214 - 0162 - Jun '12 - BunnyBoy - Bleazey BB Mount, Supermax sprocket, G56 Exhaust, Urban Cooling, Centa, Welded chassis bracing, Fairbourne Aero screen XXXX - XXXX- aug 12 - X....TR6 0250 - 0240 - Sep '12 - french owner 0334 - 0213 - Sep '12 - HJP; April '16 - Tim W 0343 - 0305 - Oct '12 - hbatts 0350 - 0367 - Oct '12 - wis cos 0364 - 0315 - Oct '12 - ArchieWetleg. Sport Green. Written off in rollover accident 14-04-2018 CAT S. If it's ever bought out of salvage and repaired contact me for some photos before you hand over the cash. Both occupants OK apart from dented pride. 0385 - 0337 - Dec '12 - KBMOG 1001 - 0396 - Dec '12 - RedThree - Centa Compensator, Replacement chassis, Replacement chassis, Comfort kit fitted, One dead rectifier, later rear hub, Stage 1 Kit - N.B. This is correct entry! 0401 - 2352 - ??? ‘12 - GPC1203 - The usual upgrades, on its second CE rectifier - Darien, Connecticut, USA 0404 - 0399 - ??? '12 - Mikethetrike 0405 - 0371 - Dec '12 - MichaelH - Comfort Kit, H-D rectifier, Three rear sprockets now SuperMax, exhaust bobbins, front Blockley tires, Centa Compensator, new clutch xxxx - 0449 - Dec. 12 - Jm 0458 - 0458 - Dec '12 - Mi3Wheeler sold to Bitsobrits March 2018 xxxx - 0495 - Jan '13 - rotobug - green/scarlet leather, comfort steering, chassis brace, urban cooling on order________________________ 0491 - xxxx - Feb '13 - CPC 0529 - XXXX - Jan '13 - MTWV2 Xxxx - 0474 - Feb '13 - Max - Superdry Xxxx - 0475 - Feb '13 - Jack - pin exhaust, rear bearings. 0539 - 0485 - Feb '13 - Raphy - Superdry centa /chssis 2015 0541 - xxxx - Feb '13 - Dab of Oppo - Gulf1 0554 - 0618 - Feb '13 - Karl K. 0579 - 0619 - May '13 - Laurens - Gulf Empire Kit 0586 - xxxx -May '13 - Cubemark - comfort kit,centa,BB,urban cooling kit, blumels wheel, Supermax, chassis brace. 0661 - xxxx - May '13 - PeteS 0050 - 0050 - May '13 - Naïves 0668 - xxxx - Apr '13 - PeterG - Sold - Centa,NVH,BB,Rectifier-chassis, Spax adj. Comfort 0674 - xxxx - Apr '13 - DocNik 0680 - 0723 - Jul '13 - emiguy 14060 - 0799 - May '13 - Planenut. New Chassis, Empire kit, G56, Centa, Fairbourne screen, steel sprocket 0705 - 0725 - May '13 - Minnemog 0712 - 0793 - Jun '13 - The Seeker 0713 - xxxx - Jun '13 - The Austrian 0727 - 0767 - May '13 - Waldemar - CentaComp, NewBB&NVH, ComfortKit, UrbanCoolingKit, HD-rectifier, third rear sprocket, 2 cowl badges, MorganPark Stage_1 with DFO, BraceKit, CamPulleyBeltUpgrade, RearMudguard, SmallTransmissionTunnel-MorganPark, GloveCompartment-MorganPark 0729 - 0763 - Jun '13 - R1NGA (Phil G) - Centa, New Sprocket/Belt, Crank/Cam Pulley Belt 'Upgrade', Rectifier, Empire Wishbones, DIY Fan, G56 Kit+ECU 0740 - 0782 - Jul '13 - CM31 0772 - 0787 - Jul '13 - bobo - comfort kit,centa,BB,urban cooling kit,crankshaft bolt failure/cover smashed 0752 - 0795 - Jul '13 - Rineke (Laurens wife) - Empire Kit 27213 - 0778 - Oct '13 - TimG - Comfort Kit, Steel rear sprocket, latest ECU, replacement chassis, Centa compensator 0758 - 0855 - Aug '13 - Mol - SQUIRLZ 0820 - 2896 - Aug '13 - Olga - Comfort Kit, centa, cooling kit, oil cooler, BB cooler 0825 - 0931 - Sep '13 - P_Dron - Comfort kit, Suplex adjustable front, crankshaft sprocket bolt/timing belt failure, 2 rectifier failures, 1 dead battery. SOLD 0856 - 0919 - Aug '13 - Black Adder 0859 - xxxx - ??? '13 - Zackybilly1 0877 - xxxx - Sep '13 - Smaug - Super Dry 0896 - 0926 - Sep '13 - Bigpoppapump 0901 - 0949 - Sep '13 - kar120c - Sport Blue/Black Leather 0905 - xxxx - Sep '13 - LarryS 0911 - 0906 - Nov '13 - Craig L 0915 Dec 13- George M 0921 - xxxx - Oct '13 - GT Tours Location 0946- HKNYMOG 0948 - 1017 - Nov '13 - Chris99 - Comfort Steering, Urban Cooling, Centra, steel rear sprocket, Stage 1 exhaust kit, Stage 2 cams, ecu and Krazy Horse dyno tune 0969 - 1299 - Oct '13 - Swiss Ghost 0958 - xxxx - Oct '13 - MOG33850 - 2014 modified at factory 1001 - xxxx - Oct '13 - Nippymog 0981 - 2179 - Apr '14 - spelunx 0975 - xxxx - Jul '14 - Owner Unknown vehicle in service 0993 - XXXX - > '13 - Bluebricked, Seattle WA, SuperDry Silver/Mulbury (Urban cooling, KH Steering, G56 Stage 1, SuperDry steering wheel, etc.....and a proper ground surface on the Centa update journal courtesy of 3Gs) 1084 - 1151 - Mar '14 - Stringers Best Mate - Dakota Grey Matte / Black Leather (Sold Feb '16) 1152 - xxxx - Apr '14 - Lotusianer 1171 - xxxx - Apr '14 - alexuels 7234 - 2301 - Feb '15 - Sport Blue/Honey Leather Stage 1 SOLD 9759 - 2312 - Mar '15 - Sportster - Sport Black/Honey Leather 11636 - 2352 - Jun '15 - Mapman - Sport Grey/Scarlet Leather 11214 - 2358 - Jun '15 - PhilipNZ - Dark Grey/Scarlet Leather 15649 - 2431 - January '16 - KenShapiro - WillowGreen/Honey 19146 - 2036 - Apr '16 - Richard Wood - Sport Green/Tan SOLD 20224 - 1299 - Dec 2016 - Brooklands Green/Black leather, C Miller 20259 - 2056 - June '16 - Mark Terlecky - Sport Red/Black 20336 - 2026-Oct '16 - Draggin - Merc. Palladium Silver/Waterproof Saddle XXXX - 2097 - Dec ’16 - Rick Kaufman - Sport Blue/Burnt Orange - USA XXXX -2098- Nov ’16 - Jim Henry - Connaught Green/Honey - USA 22895 - 2099 Nov '16 - Glenn - AM California Sage/Yarwood red leather 24156 - 2123 - Dec '16 - FastKen Cemo - Sport Red/Yarwood Honey -Build 84024 21688 - 2068 - Aug '16 - JoeJoe - Sport Green/Black XXXX - 2083 - Oct '16 - PaulR - Sport Green / Tan / MMC Stage 1 / Krazy Horse Wishbone Kit 2135 - XXXX - Mar 17 - Griff07 - Brooklands Green / Black Leather - Rudenmeister Clocks & Kuryakyn Mach 2 Air Filter 202001-84013 - April '17 - James Lyle-BRG w/Blk leather 202028-84119 - April '17 - Amir Ghorbani- Willow Green Inspired by Peter G. M3W 202039-84182 - April '17 - Chris Bachmann - Sport Green/Honey/Shark/ SF, CA 32859-202020 - April '17 - John Pavone - Sport Black/Mulbury/MMC Stage1 - USA 24622-2011 - Jan '17 - High Noon - military matte green - honey leather 32856-2069 - Sept '17 - Manufactured in June- Grey / Black leather, W Mann, NH USA 37959-2012-June ‘19 Manufacture- Ivory w/honey leather, Seattle USA
Reply Quote Report Email
Ian Morgan Family 1929 ( KTW 1100cc ) Morgan S/S 1934 Morgan F4 M3W 2012 Morgan +4 T 1991
Posts: 31 |
under VIN seat ------------------------------------------------------------ 0001 - xxxx - Feb '12 - Aeroman SOLD 0003 - xxxx - Feb '12 - Taffmog -original development car converted in 2013 to the Grim Reaper -UK 0004 - xxxx - Feb '12 - ajsms999 ex SGT DEMO 0006 - xxxx - Feb '12 - KJFB - ex Lifes DEMO 0007 - xxxx - Jan '12 - Melvyn Rutter Ltd - DEMO 0008 - xxxx - Jan '12 - Al1rhd 0009 - xxxx - Jan '12 - CSCC Sweden - DEMO 0013 - xxxx - Jan '12 - 1560 0020 - 2014 - Aug '12 - Thono Germany/Berlin - first registration in sweden ... 0027 - xxxx - Feb '12 - Tomtom 0032 - xxxx - Feb '12 - Herman01 0047 - xxxx - Feb '12 - Vitti4.3W 0049 - xxxx - Feb '12 - Asbojohn 0050 - xxxx - mar '13 - nadvys 0051 - 0051 - mar 12 Grimaud 0070-2011-March 2012 Chocadoodledoo, New Hybrid Chassis and Bodyshell( due to corrosion) in 2016. Plus Centa Drive, Comfort Kit,Urban Cooling Kit, Supermax Sprocket with modified early hub to give belt space. Nov 2019, Bleazey Driveline Conversion and crank oil seal mods. 0083 - 2048 _ Apr ,12 _ Elcyd 0109 - 2067 - Apr ,12 - Hugo ,Centa, chassis brace, comfort kit, rectifier, cam cover, cam bolts, new bearings ,steel sprocket, rear hub, 0125 - 1002 - May '12 - John Winn 0129 - 0092 - Apr '12 - JMD - new chassis/Centa/comfort kit 0130 - 0117 - Mar '12 - donaldosaurus - Convertisseur, Centa 0131 - 0083 - Apr '12 - P964 0133 - xxxx - May '12 - MTW69 0157 - xxxx - May '12 - CSCC Sweden ( ex Stig, now for sale) 0162 - 0107 - May '12 - MDH, (ex Ledgerwoods Demonstrator), Urban Cooling kit, Bonnet Latches, 12/14 Hybrid Chassis, Centa, Re-spray. New 2016 body. Steel drive pulley, Cambelt modification. Stainless cowling. 0189 - xxxx - June '12 - Robby Udine (Italy): upgraded wishbones, Blockley tyres, will have chassis bracing 0200 - 0141 - May '12 - Simmo 0214 - 0162 - Jun '12 - BunnyBoy - Bleazey BB Mount, Supermax sprocket, G56 Exhaust, Urban Cooling, Centa, Welded chassis bracing, Fairbourne Aero screen XXXX - XXXX- aug 12 - X....TR6 0250 - 0240 - Sep '12 - french owner 0334 - 0213 - Sep '12 - HJP; April '16 - Tim W 0343 - 0305 - Oct '12 - hbatts 0350 - 0367 - Oct '12 - wis cos 0364 - 0315 - Oct '12 - ArchieWetleg. Sport Green. Written off in rollover accident 14-04-2018 CAT S. If it's ever bought out of salvage and repaired contact me for some photos before you hand over the cash. Both occupants OK apart from dented pride. 0385 - 0337 - Dec '12 - KBMOG 1001 - 0396 - Dec '12 - RedThree - Centa Compensator, Replacement chassis, Replacement chassis, Comfort kit fitted, One dead rectifier, later rear hub, Stage 1 Kit - N.B. This is correct entry! 0401 - 2352 - ??? ‘12 - GPC1203 - The usual upgrades, on its second CE rectifier - Darien, Connecticut, USA 0404 - 0399 - ??? '12 - Mikethetrike 0405 - 0371 - Dec '12 - MichaelH - Comfort Kit, H-D rectifier, Three rear sprockets now SuperMax, exhaust bobbins, front Blockley tires, Centa Compensator, new clutch xxxx - 0449 - Dec. 12 - Jm 0458 - 0458 - Dec '12 - Mi3Wheeler sold to Bitsobrits March 2018 xxxx - 0495 - Jan '13 - rotobug - green/scarlet leather, comfort steering, chassis brace, urban cooling on order________________________ 0491 - xxxx - Feb '13 - CPC 0529 - XXXX - Jan '13 - MTWV2 Xxxx - 0474 - Feb '13 - Max - Superdry Xxxx - 0475 - Feb '13 - Jack - pin exhaust, rear bearings. 0539 - 0485 - Feb '13 - Raphy - Superdry centa /chssis 2015 0541 - xxxx - Feb '13 - Dab of Oppo - Gulf1 0554 - 0618 - Feb '13 - Karl K. 0579 - 0619 - May '13 - Laurens - Gulf Empire Kit 0586 - xxxx -May '13 - Cubemark - comfort kit,centa,BB,urban cooling kit, blumels wheel, Supermax, chassis brace.------------SOLD now drives PEMBLETON VSPORT----------------!!! 0661 - xxxx - May '13 - PeteS 0050 - 0050 - May '13 - Naïves 0668 - xxxx - Apr '13 - PeterG - Sold - Centa,NVH,BB,Rectifier-chassis, Spax adj. Comfort 0674 - xxxx - Apr '13 - DocNik 0680 - 0723 - Jul '13 - emiguy 14060 - 0799 - May '13 - Planenut. New Chassis, Empire kit, G56, Centa, Fairbourne screen, steel sprocket 0705 - 0725 - May '13 - Minnemog 0712 - 0793 - Jun '13 - The Seeker 0713 - xxxx - Jun '13 - The Austrian 0727 - 0767 - May '13 - Waldemar - CentaComp, NewBB&NVH, ComfortKit, UrbanCoolingKit, HD-rectifier, third rear sprocket, 2 cowl badges, MorganPark Stage_1 with DFO, BraceKit, CamPulleyBeltUpgrade, RearMudguard, SmallTransmissionTunnel-MorganPark, GloveCompartment-MorganPark 0729 - 0763 - Jun '13 - R1NGA (Phil G) - Centa, New Sprocket/Belt, Crank/Cam Pulley Belt 'Upgrade', Rectifier, Empire Wishbones, DIY Fan, G56 Kit+ECU 0740 - 0782 - Jul '13 - CM31 0772 - 0787 - Jul '13 - bobo - comfort kit,centa,BB,urban cooling kit,crankshaft bolt failure/cover smashed 0752 - 0795 - Jul '13 - Rineke (Laurens wife) - Empire Kit 27213 - 0778 - Oct '13 - TimG - Comfort Kit, Steel rear sprocket, latest ECU, replacement chassis, Centa compensator 0758 - 0855 - Aug '13 - Mol - SQUIRLZ 0820 - 2896 - Aug '13 - Olga - Comfort Kit, centa, cooling kit, oil cooler, BB cooler 0825 - 0931 - Sep '13 - P_Dron - Comfort kit, Suplex adjustable front, crankshaft sprocket bolt/timing belt failure, 2 rectifier failures, 1 dead battery. SOLD 0856 - 0919 - Aug '13 - Black Adder 0859 - xxxx - ??? '13 - Zackybilly1 0877 - xxxx - Sep '13 - Smaug - Super Dry 0896 - 0926 - Sep '13 - Bigpoppapump 0901 - 0949 - Sep '13 - kar120c - Sport Blue/Black Leather 0905 - xxxx - Sep '13 - LarryS 0911 - 0906 - Nov '13 - Craig L 0915 Dec 13- George M 0921 - xxxx - Oct '13 - GT Tours Location 0946- HKNYMOG 0948 - 1017 - Nov '13 - Chris99 - Comfort Steering, Urban Cooling, Centra, steel rear sprocket, Stage 1 exhaust kit, Stage 2 cams, ecu and Krazy Horse dyno tune 0969 - 1299 - Oct '13 - Swiss Ghost 0958 - xxxx - Oct '13 - MOG33850 - 2014 modified at factory 1001 - xxxx - Oct '13 - Nippymog 0981 - 2179 - Apr '14 - spelunx 0975 - xxxx - Jul '14 - Owner Unknown vehicle in service 0993 - XXXX - > '13 - Bluebricked, Seattle WA, SuperDry Silver/Mulbury (Urban cooling, KH Steering, G56 Stage 1, SuperDry steering wheel, etc.....and a proper ground surface on the Centa update journal courtesy of 3Gs) 1084 - 1151 - Mar '14 - Stringers Best Mate - Dakota Grey Matte / Black Leather (Sold Feb '16) 1152 - xxxx - Apr '14 - Lotusianer 1171 - xxxx - Apr '14 - alexuels 7234 - 2301 - Feb '15 - Sport Blue/Honey Leather Stage 1 SOLD 9759 - 2312 - Mar '15 - Sportster - Sport Black/Honey Leather 11636 - 2352 - Jun '15 - Mapman - Sport Grey/Scarlet Leather 11214 - 2358 - Jun '15 - PhilipNZ - Dark Grey/Scarlet Leather 15649 - 2431 - January '16 - KenShapiro - WillowGreen/Honey 19146 - 2036 - Apr '16 - Richard Wood - Sport Green/Tan SOLD 20224 - 1299 - Dec 2016 - Brooklands Green/Black leather, C Miller 20259 - 2056 - June '16 - Mark Terlecky - Sport Red/Black 20336 - 2026-Oct '16 - Draggin - Merc. Palladium Silver/Waterproof Saddle XXXX - 2097 - Dec ’16 - Rick Kaufman - Sport Blue/Burnt Orange - USA XXXX -2098- Nov ’16 - Jim Henry - Connaught Green/Honey - USA 22895 - 2099 Nov '16 - Glenn - AM California Sage/Yarwood red leather 24156 - 2123 - Dec '16 - FastKen Cemo - Sport Red/Yarwood Honey -Build 84024 21688 - 2068 - Aug '16 - JoeJoe - Sport Green/Black XXXX - 2083 - Oct '16 - PaulR - Sport Green / Tan / MMC Stage 1 / Krazy Horse Wishbone Kit 2135 - XXXX - Mar 17 - Griff07 - Brooklands Green / Black Leather - Rudenmeister Clocks & Kuryakyn Mach 2 Air Filter 202001-84013 - April '17 - James Lyle-BRG w/Blk leather 202028-84119 - April '17 - Amir Ghorbani- Willow Green Inspired by Peter G. M3W 202039-84182 - April '17 - Chris Bachmann - Sport Green/Honey/Shark/ SF, CA 32859-202020 - April '17 - John Pavone - Sport Black/Mulbury/MMC Stage1 - USA 24622-2011 - Jan '17 - High Noon - military matte green - honey leather 32856-2069 - Sept '17 - Manufactured in June- Grey / Black leather, W Mann, NH USA 37959-2012-June ‘19 Manufacture- Ivory w/honey leather, Seattle USA
was 2013 M3W, now 2017 Pembleton VSport, COMING SOON 2021 Pembleton V Sport
Posts: 1,740 Likes: 57
Posts: 1,740 Likes: 57 |
under VIN seat ------------------------------------------------------------ 0001 - xxxx - Feb '12 - Aeroman SOLD 0003 - xxxx - Feb '12 - Taffmog -original development car converted in 2013 to the Grim Reaper -UK 0004 - xxxx - Feb '12 - ajsms999 ex SGT DEMO 0006 - xxxx - Feb '12 - KJFB - ex Lifes DEMO 0007 - xxxx - Jan '12 - Melvyn Rutter Ltd - DEMO 0008 - xxxx - Jan '12 - Al1rhd 0009 - xxxx - Jan '12 - CSCC Sweden - DEMO 0013 - xxxx - Jan '12 - 1560 0020 - 2014 - Aug '12 - Thono Germany/Berlin - first registration in sweden ... 0027 - xxxx - Feb '12 - Tomtom 0032 - xxxx - Feb '12 - Herman01 0047 - xxxx - Feb '12 - Vitti4.3W 0049 - xxxx - Feb '12 - Asbojohn 0050 - xxxx - mar '13 - nadvys 0051 - 0051 - mar 12 Grimaud 0070-2011-March 2012 Chocadoodledoo, New Hybrid Chassis and Bodyshell( due to corrosion) in 2016. Plus Centa Drive, Comfort Kit,Urban Cooling Kit, Supermax Sprocket with modified early hub to give belt space. Nov 2019, Bleazey Driveline Conversion and crank oil seal mods. 0083 - 2048 _ Apr ,12 _ Elcyd 0109 - 2067 - Apr ,12 - Hugo ,Centa, chassis brace, comfort kit, rectifier, cam cover, cam bolts, new bearings ,steel sprocket, rear hub, 0125 - 1002 - May '12 - John Winn 0129 - 0092 - Apr '12 - JMD - new chassis/Centa/comfort kit 0130 - 0117 - Mar '12 - donaldosaurus - Convertisseur, Centa 0131 - 0083 - Apr '12 - P964 0133 - xxxx - May '12 - MTW69 0157 - xxxx - May '12 - CSCC Sweden ( ex Stig, now for sale) 0162 - 0107 - May '12 - MDH, (ex Ledgerwoods Demonstrator), Urban Cooling kit, Bonnet Latches, 12/14 Hybrid Chassis, Centa, Re-spray. New 2016 body. Steel drive pulley, Cambelt modification. Stainless cowling. 0189 - xxxx - June '12 - Robby Udine (Italy): upgraded wishbones, Blockley tyres, will have chassis bracing 0200 - 0141 - May '12 - Simmo 0214 - 0162 - Jun '12 - BunnyBoy - Bleazey BB Mount & Centa Mods, Supermax sprocket, G56 Exhaust, Urban Cooling, Welded chassis bracing, Fairbourne Aero screen XXXX - XXXX- aug 12 - X....TR6 0250 - 0240 - Sep '12 - french owner 0334 - 0213 - Sep '12 - HJP; April '16 - Tim W 0343 - 0305 - Oct '12 - hbatts 0350 - 0367 - Oct '12 - wis cos 0364 - 0315 - Oct '12 - ArchieWetleg. Sport Green. Written off in rollover accident 14-04-2018 CAT S. If it's ever bought out of salvage and repaired contact me for some photos before you hand over the cash. Both occupants OK apart from dented pride. 0385 - 0337 - Dec '12 - KBMOG 1001 - 0396 - Dec '12 - RedThree - Centa Compensator, Replacement chassis, Replacement chassis, Comfort kit fitted, One dead rectifier, later rear hub, Stage 1 Kit - N.B. This is correct entry! 0401 - 2352 - ??? ‘12 - GPC1203 - The usual upgrades, on its second CE rectifier - Darien, Connecticut, USA 0404 - 0399 - ??? '12 - Mikethetrike 0405 - 0371 - Dec '12 - MichaelH - Comfort Kit, H-D rectifier, Three rear sprockets now SuperMax, exhaust bobbins, front Blockley tires, Centa Compensator, new clutch xxxx - 0449 - Dec. 12 - Jm 0458 - 0458 - Dec '12 - Mi3Wheeler sold to Bitsobrits March 2018 xxxx - 0495 - Jan '13 - rotobug - green/scarlet leather, comfort steering, chassis brace, urban cooling on order________________________ 0491 - xxxx - Feb '13 - CPC 0529 - XXXX - Jan '13 - MTWV2 Xxxx - 0474 - Feb '13 - Max - Superdry Xxxx - 0475 - Feb '13 - Jack - pin exhaust, rear bearings. 0539 - 0485 - Feb '13 - Raphy - Superdry centa /chssis 2015 0541 - xxxx - Feb '13 - Dab of Oppo - Gulf1 0554 - 0618 - Feb '13 - Karl K. 0579 - 0619 - May '13 - Laurens - Gulf Empire Kit 0586 - xxxx -May '13 - Cubemark - comfort kit,centa,BB,urban cooling kit, blumels wheel, Supermax, chassis brace.------------SOLD now drives PEMBLETON VSPORT----------------!!! 0661 - xxxx - May '13 - PeteS 0050 - 0050 - May '13 - Naïves 0668 - xxxx - Apr '13 - PeterG - Sold - Centa,NVH,BB,Rectifier-chassis, Spax adj. Comfort 0674 - xxxx - Apr '13 - DocNik 0680 - 0723 - Jul '13 - emiguy 14060 - 0799 - May '13 - Planenut. New Chassis, Empire kit, G56, Centa, Fairbourne screen, steel sprocket 0705 - 0725 - May '13 - Minnemog 0712 - 0793 - Jun '13 - The Seeker 0713 - xxxx - Jun '13 - The Austrian 0727 - 0767 - May '13 - Waldemar - CentaComp, NewBB&NVH, ComfortKit, UrbanCoolingKit, HD-rectifier, third rear sprocket, 2 cowl badges, MorganPark Stage_1 with DFO, BraceKit, CamPulleyBeltUpgrade, RearMudguard, SmallTransmissionTunnel-MorganPark, GloveCompartment-MorganPark 0729 - 0763 - Jun '13 - R1NGA (Phil G) - Centa, New Sprocket/Belt, Crank/Cam Pulley Belt 'Upgrade', Rectifier, Empire Wishbones, DIY Fan, G56 Kit+ECU 0740 - 0782 - Jul '13 - CM31 0772 - 0787 - Jul '13 - bobo - comfort kit,centa,BB,urban cooling kit,crankshaft bolt failure/cover smashed 0752 - 0795 - Jul '13 - Rineke (Laurens wife) - Empire Kit 27213 - 0778 - Oct '13 - TimG - Comfort Kit, Steel rear sprocket, latest ECU, replacement chassis, Centa compensator 0758 - 0855 - Aug '13 - Mol - SQUIRLZ 0820 - 2896 - Aug '13 - Olga - Comfort Kit, centa, cooling kit, oil cooler, BB cooler 0825 - 0931 - Sep '13 - P_Dron - Comfort kit, Suplex adjustable front, crankshaft sprocket bolt/timing belt failure, 2 rectifier failures, 1 dead battery. SOLD 0856 - 0919 - Aug '13 - Black Adder 0859 - xxxx - ??? '13 - Zackybilly1 0877 - xxxx - Sep '13 - Smaug - Super Dry 0896 - 0926 - Sep '13 - Bigpoppapump 0901 - 0949 - Sep '13 - kar120c - Sport Blue/Black Leather 0905 - xxxx - Sep '13 - LarryS 0911 - 0906 - Nov '13 - Craig L 0915 Dec 13- George M 0921 - xxxx - Oct '13 - GT Tours Location 0946- HKNYMOG 0948 - 1017 - Nov '13 - Chris99 - Comfort Steering, Urban Cooling, Centra, steel rear sprocket, Stage 1 exhaust kit, Stage 2 cams, ecu and Krazy Horse dyno tune 0969 - 1299 - Oct '13 - Swiss Ghost 0958 - xxxx - Oct '13 - MOG33850 - 2014 modified at factory 1001 - xxxx - Oct '13 - Nippymog 0981 - 2179 - Apr '14 - spelunx 0975 - xxxx - Jul '14 - Owner Unknown vehicle in service 0993 - XXXX - > '13 - Bluebricked, Seattle WA, SuperDry Silver/Mulbury (Urban cooling, KH Steering, G56 Stage 1, SuperDry steering wheel, etc.....and a proper ground surface on the Centa update journal courtesy of 3Gs) 1084 - 1151 - Mar '14 - Stringers Best Mate - Dakota Grey Matte / Black Leather (Sold Feb '16) 1152 - xxxx - Apr '14 - Lotusianer 1171 - xxxx - Apr '14 - alexuels 7234 - 2301 - Feb '15 - Sport Blue/Honey Leather Stage 1 SOLD 9759 - 2312 - Mar '15 - Sportster - Sport Black/Honey Leather 11636 - 2352 - Jun '15 - Mapman - Sport Grey/Scarlet Leather 11214 - 2358 - Jun '15 - PhilipNZ - Dark Grey/Scarlet Leather 15649 - 2431 - January '16 - KenShapiro - WillowGreen/Honey 19146 - 2036 - Apr '16 - Richard Wood - Sport Green/Tan SOLD 20224 - 1299 - Dec 2016 - Brooklands Green/Black leather, C Miller 20259 - 2056 - June '16 - Mark Terlecky - Sport Red/Black 20336 - 2026-Oct '16 - Draggin - Merc. Palladium Silver/Waterproof Saddle XXXX - 2097 - Dec ’16 - Rick Kaufman - Sport Blue/Burnt Orange - USA XXXX -2098- Nov ’16 - Jim Henry - Connaught Green/Honey - USA 22895 - 2099 Nov '16 - Glenn - AM California Sage/Yarwood red leather 24156 - 2123 - Dec '16 - FastKen Cemo - Sport Red/Yarwood Honey -Build 84024 21688 - 2068 - Aug '16 - JoeJoe - Sport Green/Black XXXX - 2083 - Oct '16 - PaulR - Sport Green / Tan / MMC Stage 1 / Krazy Horse Wishbone Kit 2135 - XXXX - Mar 17 - Griff07 - Brooklands Green / Black Leather - Rudenmeister Clocks & Kuryakyn Mach 2 Air Filter 202001-84013 - April '17 - James Lyle-BRG w/Blk leather 202028-84119 - April '17 - Amir Ghorbani- Willow Green Inspired by Peter G. M3W 202039-84182 - April '17 - Chris Bachmann - Sport Green/Honey/Shark/ SF, CA 32859-202020 - April '17 - John Pavone - Sport Black/Mulbury/MMC Stage1 - USA 24622-2011 - Jan '17 - High Noon - military matte green - honey leather 32856-2069 - Sept '17 - Manufactured in June- Grey / Black leather, W Mann, NH USA 37959-2012-June ‘19 Manufacture- Ivory w/honey leather, Seattle USA
Andy
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
under VIN seat ------------------------------------------------------------ 0001 - xxxx - Feb '12 - Aeroman SOLD 0003 - xxxx - Feb '12 - Taffmog -original development car converted in 2013 to the Grim Reaper -UK 0004 - xxxx - Feb '12 - ajsms999 ex SGT DEMO 0006 - xxxx - Feb '12 - KJFB - ex Lifes DEMO 0007 - xxxx - Jan '12 - Melvyn Rutter Ltd - DEMO 0008 - xxxx - Jan '12 - Al1rhd 0009 - xxxx - Jan '12 - CSCC Sweden - DEMO 0013 - xxxx - Jan '12 - 1560 0020 - 2014 - Aug '12 - Thono Germany/Berlin - first registration in sweden ... 0027 - xxxx - Feb '12 - Tomtom 0032 - xxxx - Feb '12 - Herman01 0047 - xxxx - Feb '12 - Vitti4.3W 0049 - xxxx - Feb '12 - Asbojohn 0050 - xxxx - mar '13 - nadvys 0051 - 0051 - mar 12 Grimaud 0070-2011-March 2012 Chocadoodledoo, New Hybrid Chassis and Bodyshell( due to corrosion) in 2016. Plus Centa Drive, Comfort Kit,Urban Cooling Kit, Supermax Sprocket with modified early hub to give belt space. Nov 2019, Bleazey Driveline Conversion and crank oil seal mods. 0083 - 2048 _ Apr ,12 _ Elcyd 0109 - 2067 - Apr ,12 - Hugo ,Centa, chassis brace, comfort kit, rectifier, cam cover, cam bolts, new bearings ,steel sprocket, rear hub, 0125 - 1002 - May '12 - John Winn 0129 - 0092 - Apr '12 - JMD - new chassis/Centa/comfort kit 0130 - 0117 - Mar '12 - donaldosaurus - Convertisseur, Centa 0131 - 0083 - Apr '12 - P964 0133 - xxxx - May '12 - MTW69 0157 - xxxx - May '12 - CSCC Sweden ( ex Stig, now for sale) 0162 - 0107 - May '12 - MDH, (ex Ledgerwoods Demonstrator), Urban Cooling kit, Bonnet Latches, 12/14 Hybrid Chassis, Centa, Re-spray. New 2016 body. Steel drive pulley, Cambelt modification. Stainless cowling. 0189 - xxxx - June '12 - Robby Udine (Italy): upgraded wishbones, Blockley tyres, will have chassis bracing 0200 - 0141 - May '12 - Simmo 0214 - 0162 - Jun '12 - BunnyBoy - Bleazey BB Mount & Centa Mods, Supermax sprocket, G56 Exhaust, Urban Cooling, Welded chassis bracing, Fairbourne Aero screen XXXX - XXXX- aug 12 - X....TR6 0250 - 0240 - Sep '12 - french owner 0334 - 0213 - Sep '12 - HJP; April '16 - Tim W 0343 - 0305 - Oct '12 - hbatts 0350 - 0367 - Oct '12 - wis cos 0364 - 0315 - Oct '12 - ArchieWetleg. Sport Green. Written off in rollover accident 14-04-2018 CAT S. If it's ever bought out of salvage and repaired contact me for some photos before you hand over the cash. Both occupants OK apart from dented pride. 0385 - 0337 - Dec '12 - KBMOG 1001 - 0396 - Dec '12 - RedThree - Centa Compensator, Replacement chassis, Replacement chassis, Comfort kit fitted, One dead rectifier, later rear hub, Stage 1 Kit - N.B. This is correct entry! 0401 - 2352 - ??? ‘12 - GPC1203 - The usual upgrades, on its second CE rectifier - Darien, Connecticut, USA 0404 - 0399 - ??? '12 - Mikethetrike 0405 - 0371 - Dec '12 - MichaelH - Comfort Kit, H-D rectifier, Three rear sprockets now SuperMax, exhaust bobbins, front Blockley tires, Centa Compensator, new clutch xxxx - 0449 - Dec. 12 - Jm 0458 - 0458 - Dec '12 - Mi3Wheeler sold to Bitsobrits March 2018 xxxx - 0495 - Jan '13 - rotobug - green/scarlet leather, comfort steering, chassis brace, urban cooling on order________________________ 0491 - xxxx - Feb '13 - CPC 0529 - XXXX - Jan '13 - MTWV2 Xxxx - 0474 - Feb '13 - Max - Superdry Xxxx - 0475 - Feb '13 - Jack - pin exhaust, rear bearings. 0539 - 0485 - Feb '13 - Raphy - Superdry centa /chssis 2015 0541 - xxxx - Feb '13 - Dab of Oppo - Gulf1 0554 - 0618 - Feb '13 - Karl K. 0579 - 0619 - May '13 - Laurens - Gulf Empire Kit 0586 - xxxx -May '13 - Cubemark - comfort kit,centa,BB,urban cooling kit, blumels wheel, Supermax, chassis brace.------------SOLD now drives PEMBLETON VSPORT----------------!!! 0661 - xxxx - May '13 - PeteS 0050 - 0050 - May '13 - Naïves 0668 - xxxx - Apr '13 - PeterG - Sold - Centa,NVH,BB,Rectifier-chassis, Spax adj. Comfort 0674 - xxxx - Apr '13 - DocNik 0680 - 0723 - Jul '13 - emiguy 14060 - 0799 - May '13 - Planenut. New Chassis, Empire kit, G56, Centa, Fairbourne screen, steel sprocket 0705 - 0725 - May '13 - Minnemog 0712 - 0793 - Jun '13 - The Seeker 0713 - xxxx - Jun '13 - The Austrian 0727 - 0767 - May '13 - Waldemar - CentaComp, NewBB&NVH, ComfortKit, UrbanCoolingKit, HD-rectifier, third rear sprocket, 2 cowl badges, MorganPark Stage_1 with DFO, BraceKit, CamPulleyBeltUpgrade, RearMudguard, SmallTransmissionTunnel-MorganPark, GloveCompartment-MorganPark 0729 - 0763 - Jun '13 - R1NGA (Phil G) - Centa, New Sprocket/Belt, Crank/Cam Pulley Belt 'Upgrade', Rectifier, Empire Wishbones, DIY Fan, G56 Kit+ECU 0740 - 0782 - Jul '13 - CM31 0772 - 0787 - Jul '13 - bobo - comfort kit,centa,BB,urban cooling kit,crankshaft bolt failure/cover smashed 0752 - 0795 - Jul '13 - Rineke (Laurens wife) - Empire Kit 27213 - 0778 - Oct '13 - TimG - Comfort Kit, Steel rear sprocket, latest ECU, replacement chassis, Centa compensator 0758 - 0855 - Aug '13 - Mol - SQUIRLZ 0820 - 2896 - Aug '13 - Olga - Comfort Kit, centa, cooling kit, oil cooler, BB cooler 0825 - 0931 - Sep '13 - P_Dron - Comfort kit, Suplex adjustable front, crankshaft sprocket bolt/timing belt failure, 2 rectifier failures, 1 dead battery. SOLD 0856 - 0919 - Aug '13 - Black Adder 0859 - xxxx - ??? '13 - Zackybilly1 0877 - xxxx - Sep '13 - Smaug - Super Dry 0896 - 0926 - Sep '13 - Bigpoppapump 0901 - 0949 - Sep '13 - kar120c - Sport Blue/Black Leather 0905 - xxxx - Sep '13 - LarryS 0911 - 0906 - Nov '13 - Craig L 0915 Dec 13- George M 0921 - xxxx - Oct '13 - GT Tours Location 0946- HKNYMOG 0948 - 1017 - Nov '13 - Chris99 - Comfort Steering, Urban Cooling, Centra, steel rear sprocket, Stage 1 exhaust kit, Stage 2 cams, ecu and Krazy Horse dyno tune 0969 - 1299 - Oct '13 - Swiss Ghost 0958 - xxxx - Oct '13 - MOG33850 - 2014 modified at factory 1001 - xxxx - Oct '13 - Nippymog 0981 - 2179 - Apr '14 - spelunx 0975 - xxxx - Jul '14 - Owner Unknown vehicle in service 0993 - XXXX - > '13 - Bluebricked, Seattle WA, SuperDry Silver/Mulbury (Urban cooling, KH Steering, G56 Stage 1, SuperDry steering wheel, etc.....and a proper ground surface on the Centa update journal courtesy of 3Gs) 1084 - 1151 - Mar '14 - Stringers Best Mate - Dakota Grey Matte / Black Leather (Sold Feb '16) 1152 - xxxx - Apr '14 - Lotusianer 1171 - xxxx - Apr '14 - alexuels 7234 - 2301 - Feb '15 - Sport Blue/Honey Leather Stage 1 SOLD 9759 - 2312 - Mar '15 - Sportster - Sport Black/Honey Leather 11636 - 2352 - Jun '15 - Mapman - Sport Grey/Scarlet Leather 11214 - 2358 - Jun '15 - PhilipNZ - Dark Grey/Scarlet Leather 15649 - 2431 - January '16 - KenShapiro - WillowGreen/Honey 19146 - 2036 - Apr '16 - Richard Wood - Sport Green/Tan SOLD 20224 - 1299 - Dec 2016 - Brooklands Green/Black leather, C Miller 20259 - 2056 - June '16 - Mark Terlecky - Sport Red/Black 20336 - 2026-Oct '16 - Draggin - Merc. Palladium Silver/Waterproof Saddle XXXX - 2097 - Dec ’16 - Rick Kaufman - Sport Blue/Burnt Orange - USA XXXX -2098- Nov ’16 - Jim Henry - Connaught Green/Honey - USA 22895 - 2099 Nov '16 - Glenn - AM California Sage/Yarwood red leather 24156 - 2123 - Dec '16 - FastKen Cemo - Sport Red/Yarwood Honey -Build 84024 21688 - 2068 - Aug '16 - JoeJoe - Sport Green/Black XXXX - 2083 - Oct '16 - PaulR - Sport Green / Tan / MMC Stage 1 / Krazy Horse Wishbone Kit 2135 - XXXX - Mar 17 - Griff07 - Brooklands Green / Black Leather - Rudenmeister Clocks & Kuryakyn Mach 2 Air Filter 202001-84013 - April '17 - James Lyle-BRG w/Blk leather 202028-84119 - April '17 - Amir Ghorbani- Willow Green Inspired by Peter G. M3W 202039-84182 - April '17 - Chris Bachmann - Sport Green/Honey/Shark/ SF, CA 32859-202020 - April '17 - John Pavone - Sport Black/Mulbury/MMC Stage1 - USA 24622-2011 - Jan '17 - High Noon - military matte green - honey leather 32856-2069 - Sept '17 - Manufactured in June- Grey / Black leather, W Mann, NH USA 37959-2012-June ‘19 -Manufacture- Stephen Sweeney- Ivory w/honey leather, Seattle USA
Posts: 99 Likes: 1
Posts: 99 Likes: 1 |
Add:
326 - 307 July 2012 Delivered Arizona Oct. 2012 Chassis Brace upgrade, cam belt/bolts upgrade, Fairbourne screens. No other major issues to date. Original owner. TomS
Posts: 1,016 Likes: 2
Posts: 1,016 Likes: 2 |
under VIN seat ------------------------------------------------------------ 0001 - xxxx - Feb '12 - Aeroman SOLD 0003 - xxxx - Feb '12 - Taffmog -original development car converted in 2013 to the Grim Reaper -UK 0004 - xxxx - Feb '12 - ajsms999 ex SGT DEMO 0006 - xxxx - Feb '12 - KJFB - ex Lifes DEMO 0007 - xxxx - Jan '12 - Melvyn Rutter Ltd - DEMO 0008 - xxxx - Jan '12 - Al1rhd 0009 - xxxx - Jan '12 - CSCC Sweden - DEMO 0013 - xxxx - Jan '12 - 1560 0020 - 2014 - Aug '12 - Thono Germany/Berlin - first registration in sweden ... 0027 - xxxx - Feb '12 - Tomtom 0032 - xxxx - Feb '12 - Herman01 0047 - xxxx - Feb '12 - Vitti4.3W 0049 - xxxx - Feb '12 - Asbojohn 0050 - xxxx - mar '13 - nadvys 0051 - 0051 - mar 12 Grimaud 0070-2011-March 2012 Chocadoodledoo, New Hybrid Chassis and Bodyshell( due to corrosion) in 2016. Plus Centa Drive, Comfort Kit,Urban Cooling Kit, Supermax Sprocket with modified early hub to give belt space. Nov 2019, Bleazey Driveline Conversion and crank oil seal mods. 0083 - 2048 _ Apr ,12 _ Elcyd 0109 - 2067 - Apr ,12 - Hugo ,Centa, chassis brace, comfort kit, rectifier, cam cover, cam bolts, new bearings ,steel sprocket, rear hub, 0125 - 1002 - May '12 - John Winn 0129 - 0092 - Apr '12 - JMD - new chassis/Centa/comfort kit 0130 - 0117 - Mar '12 - donaldosaurus - Convertisseur, Centa 0131 - 0083 - Apr '12 - P964 0133 - xxxx - May '12 - MTW69 0157 - xxxx - May '12 - CSCC Sweden ( ex Stig, now for sale) 0162 - 0107 - May '12 - MDH, (ex Ledgerwoods Demonstrator), Urban Cooling kit, Bonnet Latches, 12/14 Hybrid Chassis, Centa, Re-spray. New 2016 body. Steel drive pulley, Cambelt modification. Stainless cowling. 0189 - xxxx - June '12 - Robby Udine (Italy): upgraded wishbones, Blockley tyres, will have chassis bracing 0200 - 0141 - May '12 - Simmo 0214 - 0162 - Jun '12 - BunnyBoy - Bleazey BB Mount & Centa Mods, Supermax sprocket, G56 Exhaust, Urban Cooling, Welded chassis bracing, Fairbourne Aero screen XXXX - XXXX- aug 12 - X....TR6 0250 - 0240 - Sep '12 - french owner 0326 - 0307 - Jul '12 - Delivered Arizona Oct. 2012 Chassis Brace upgrade, cam belt/bolts upgrade, Fairbourne screens. No other major issues to date. Original owner. TomS 0334 - 0213 - Sep '12 - HJP; April '16 - Tim W 0343 - 0305 - Oct '12 - hbatts 0350 - 0367 - Oct '12 - wis cos 0364 - 0315 - Oct '12 - ArchieWetleg. Sport Green. Written off in rollover accident 14-04-2018 CAT S. If it's ever bought out of salvage and repaired contact me for some photos before you hand over the cash. Both occupants OK apart from dented pride. 0385 - 0337 - Dec '12 - KBMOG 1001 - 0396 - Dec '12 - RedThree - Centa Compensator, Replacement chassis, Replacement chassis, Comfort kit fitted, One dead rectifier, later rear hub, Stage 1 Kit - N.B. This is correct entry! 0401 - 2352 - ??? ‘12 - GPC1203 - The usual upgrades, on its second CE rectifier - Darien, Connecticut, USA 0404 - 0399 - ??? '12 - Mikethetrike 0405 - 0371 - Dec '12 - MichaelH - Comfort Kit, H-D rectifier, Three rear sprockets now SuperMax, exhaust bobbins, front Blockley tires, Centa Compensator, new clutch xxxx - 0449 - Dec. 12 - Jm 0458 - 0458 - Dec '12 - Mi3Wheeler sold to Bitsobrits March 2018 xxxx - 0495 - Jan '13 - rotobug - green/scarlet leather, comfort steering, chassis brace, urban cooling on order________________________ 0491 - xxxx - Feb '13 - CPC 0529 - XXXX - Jan '13 - MTWV2 Xxxx - 0474 - Feb '13 - Max - Superdry Xxxx - 0475 - Feb '13 - Jack - pin exhaust, rear bearings. 0539 - 0485 - Feb '13 - Raphy - Superdry centa /chssis 2015 0541 - xxxx - Feb '13 - Dab of Oppo - Gulf1 0554 - 0618 - Feb '13 - Karl K. 0579 - 0619 - May '13 - Laurens - Gulf Empire Kit 0586 - xxxx -May '13 - Cubemark - comfort kit,centa,BB,urban cooling kit, blumels wheel, Supermax, chassis brace.------------SOLD now drives PEMBLETON VSPORT----------------!!! 0661 - xxxx - May '13 - PeteS 0050 - 0050 - May '13 - Naïves 0668 - xxxx - Apr '13 - PeterG - Sold - Centa,NVH,BB,Rectifier-chassis, Spax adj. Comfort 0674 - xxxx - Apr '13 - DocNik 0680 - 0723 - Jul '13 - emiguy 14060 - 0799 - May '13 - Planenut. New Chassis, Empire kit, G56, Centa, Fairbourne screen, steel sprocket 0705 - 0725 - May '13 - Minnemog 0712 - 0793 - Jun '13 - The Seeker 0713 - xxxx - Jun '13 - The Austrian 0727 - 0767 - May '13 - Waldemar - CentaComp, NewBB&NVH, ComfortKit, UrbanCoolingKit, HD-rectifier, third rear sprocket, 2 cowl badges, MorganPark Stage_1 with DFO, BraceKit, CamPulleyBeltUpgrade, RearMudguard, SmallTransmissionTunnel-MorganPark, GloveCompartment-MorganPark 0729 - 0763 - Jun '13 - R1NGA (Phil G) - Centa, New Sprocket/Belt, Crank/Cam Pulley Belt 'Upgrade', Rectifier, Empire Wishbones, DIY Fan, G56 Kit+ECU 0740 - 0782 - Jul '13 - CM31 0772 - 0787 - Jul '13 - bobo - comfort kit,centa,BB,urban cooling kit,crankshaft bolt failure/cover smashed 0752 - 0795 - Jul '13 - Rineke (Laurens wife) - Empire Kit 27213 - 0778 - Oct '13 - TimG - Comfort Kit, Steel rear sprocket, latest ECU, replacement chassis, Centa compensator 0758 - 0855 - Aug '13 - Mol - SQUIRLZ 0820 - 2896 - Aug '13 - Olga - Comfort Kit, centa, cooling kit, oil cooler, BB cooler 0825 - 0931 - Sep '13 - P_Dron - Comfort kit, Suplex adjustable front, crankshaft sprocket bolt/timing belt failure, 2 rectifier failures, 1 dead battery. SOLD 0856 - 0919 - Aug '13 - Black Adder 0859 - xxxx - ??? '13 - Zackybilly1 0877 - xxxx - Sep '13 - Smaug - Super Dry 0896 - 0926 - Sep '13 - Bigpoppapump 0901 - 0949 - Sep '13 - kar120c - Sport Blue/Black Leather 0905 - xxxx - Sep '13 - LarryS 0911 - 0906 - Nov '13 - Craig L 0915 Dec 13- George M 0921 - xxxx - Oct '13 - GT Tours Location 0946- HKNYMOG 0948 - 1017 - Nov '13 - Chris99 - Comfort Steering, Urban Cooling, Centra, steel rear sprocket, Stage 1 exhaust kit, Stage 2 cams, ecu and Krazy Horse dyno tune 0969 - 1299 - Oct '13 - Swiss Ghost 0958 - xxxx - Oct '13 - MOG33850 - 2014 modified at factory 1001 - xxxx - Oct '13 - Nippymog 0981 - 2179 - Apr '14 - spelunx 0975 - xxxx - Jul '14 - Owner Unknown vehicle in service 0993 - XXXX - > '13 - Bluebricked, Seattle WA, SuperDry Silver/Mulbury (Urban cooling, KH Steering, G56 Stage 1, SuperDry steering wheel, etc.....and a proper ground surface on the Centa update journal courtesy of 3Gs) 1084 - 1151 - Mar '14 - Stringers Best Mate - Dakota Grey Matte / Black Leather (Sold Feb '16) 1152 - xxxx - Apr '14 - Lotusianer 1171 - xxxx - Apr '14 - alexuels 7234 - 2301 - Feb '15 - Sport Blue/Honey Leather Stage 1 SOLD 9759 - 2312 - Mar '15 - Sportster - Sport Black/Honey Leather 11636 - 2352 - Jun '15 - Mapman - Sport Grey/Scarlet Leather 11214 - 2358 - Jun '15 - PhilipNZ - Dark Grey/Scarlet Leather 15649 - 2431 - January '16 - KenShapiro - WillowGreen/Honey 19146 - 2036 - Apr '16 - Richard Wood - Sport Green/Tan SOLD 20224 - 1299 - Dec 2016 - Brooklands Green/Black leather, C Miller 20259 - 2056 - June '16 - Mark Terlecky - Sport Red/Black 20336 - 2026-Oct '16 - Draggin - Merc. Palladium Silver/Waterproof Saddle XXXX - 2097 - Dec ’16 - Rick Kaufman - Sport Blue/Burnt Orange - USA XXXX -2098- Nov ’16 - Jim Henry - Connaught Green/Honey - USA 22895 - 2099 Nov '16 - Glenn - AM California Sage/Yarwood red leather 24156 - 2123 - Dec '16 - FastKen Cemo - Sport Red/Yarwood Honey -Build 84024 21688 - 2068 - Aug '16 - JoeJoe - Sport Green/Black XXXX - 2083 - Oct '16 - PaulR - Sport Green / Tan / MMC Stage 1 / Krazy Horse Wishbone Kit 2135 - XXXX - Mar 17 - Griff07 - Brooklands Green / Black Leather - Rudenmeister Clocks & Kuryakyn Mach 2 Air Filter 202001-84013 - April '17 - James Lyle-BRG w/Blk leather 202028-84119 - April '17 - Amir Ghorbani- Willow Green Inspired by Peter G. M3W 202039-84182 - April '17 - Chris Bachmann - Sport Green/Honey/Shark/ SF, CA 32859-202020 - April '17 - John Pavone - Sport Black/Mulbury/MMC Stage1 - USA 24622-2011 - Jan '17 - High Noon - military matte green - honey leather 32856-2069 - Sept '17 - Manufactured in June- Grey / Black leather, W Mann, NH USA 37959-2012-June ‘19 Manufacture- Ivory w/honey leather, Seattle USA
Add:
326 - 307 July 2012 Delivered Arizona Oct. 2012 Chassis Brace upgrade, cam belt/bolts upgrade, Fairbourne screens. No other major issues to date. Original owner. TomS Done!
Posts: 5,017 Likes: 3
Posts: 5,017 Likes: 3 |
under VIN seat ------------------------------------------------------------ 0001 - xxxx - Feb '12 - Aeroman SOLD 0003 - xxxx - Feb '12 - Taffmog -original development car converted in 2013 to the Grim Reaper -UK 0004 - xxxx - Feb '12 - ajsms999 ex SGT DEMO 0006 - xxxx - Feb '12 - KJFB - ex Lifes DEMO 0007 - xxxx - Jan '12 - Melvyn Rutter Ltd - DEMO 0008 - xxxx - Jan '12 - Al1rhd 0009 - xxxx - Jan '12 - CSCC Sweden - DEMO 0013 - xxxx - Jan '12 - 1560 0020 - 2014 - Aug '12 - Thono Germany/Berlin - first registration in sweden ... 0027 - xxxx - Feb '12 - Tomtom 0032 - xxxx - Feb '12 - Herman01 0047 - xxxx - Feb '12 - Vitti4.3W 0049 - xxxx - Feb '12 - Asbojohn 0050 - xxxx - mar '13 - nadvys 0051 - 0051 - mar 12 Grimaud 0070-2011-March 2012 Chocadoodledoo, New Hybrid Chassis and Bodyshell( due to corrosion) in 2016. Plus Centa Drive, Comfort Kit,Urban Cooling Kit, Supermax Sprocket with modified early hub to give belt space. Nov 2019, Bleazey Driveline Conversion and crank oil seal mods. 0083 - 2048 _ Apr ,12 _ Elcyd 0109 - 2067 - Apr ,12 - Hugo ,Centa, chassis brace, comfort kit, rectifier, cam cover, cam bolts, new bearings ,steel sprocket, rear hub, 0125 - 1002 - May '12 - John Winn 0129 - 0092 - Apr '12 - JMD - new chassis/Centa/comfort kit 0130 - 0117 - Mar '12 - donaldosaurus - Convertisseur, Centa 0131 - 0083 - Apr '12 - P964 0133 - xxxx - May '12 - MTW69 0157 - xxxx - May '12 - CSCC Sweden ( ex Stig, now for sale) 0162 - 0107 - May '12 - MDH, (ex Ledgerwoods Demonstrator), Urban Cooling kit, Bonnet Latches, 12/14 Hybrid Chassis, Centa, Re-spray. New 2016 body. Steel drive pulley, Cambelt modification. Stainless cowling. 0189 - xxxx - June '12 - Robby Udine (Italy): upgraded wishbones, Blockley tyres, will have chassis bracing 0200 - 0141 - May '12 - Simmo 0214 - 0162 - Jun '12 - BunnyBoy - Bleazey BB Mount & Centa Mods, Supermax sprocket, G56 Exhaust, Urban Cooling, Welded chassis bracing, Fairbourne Aero screen XXXX - XXXX- aug 12 - X....TR6 0250 - 0240 - Sep '12 - french owner 0326 - 0307 - Jul '12 - Delivered Arizona Oct. 2012 Chassis Brace upgrade, cam belt/bolts upgrade, Fairbourne screens. No other major issues to date. Original owner. TomS 0334 - 0213 - Sep '12 - HJP; April '16 - Tim W 0343 - 0305 - Oct '12 - hbatts 0350 - 0367 - Oct '12 - wis cos 0364 - 0315 - Oct '12 - ArchieWetleg. Sport Green. Written off in rollover accident 14-04-2018 CAT S. If it's ever bought out of salvage and repaired contact me for some photos before you hand over the cash. Both occupants OK apart from dented pride. 0385 - 0337 - Dec '12 - KBMOG 1001 - 0396 - Dec '12 - RedThree - Centa Compensator, Replacement chassis, Replacement chassis, Comfort kit fitted, One dead rectifier, later rear hub, Stage 1 Kit - N.B. This is correct entry! 0401 - 2352 - ??? ‘12 - GPC1203 - The usual upgrades, on its second CE rectifier - Darien, Connecticut, USA 0404 - 0399 - ??? '12 - Mikethetrike 0405 - 0371 - Dec '12 - MichaelH - Comfort Kit, H-D rectifier, Three rear sprockets now SuperMax, exhaust bobbins, front Blockley tires, Centa Compensator, new clutch xxxx - 0449 - Dec. 12 - Jm 0458 - 0458 - Dec '12 - Mi3Wheeler sold to Bitsobrits March 2018 xxxx - 0495 - Jan '13 - rotobug - green/scarlet leather, comfort steering, chassis brace, urban cooling on order________________________ 0491 - xxxx - Feb '13 - CPC 0529 - XXXX - Jan '13 - MTWV2 Xxxx - 0474 - Feb '13 - Max - Superdry Xxxx - 0475 - Feb '13 - Jack - pin exhaust, rear bearings. 0539 - 0485 - Feb '13 - Raphy - Superdry centa /chssis 2015 0541 - xxxx - Feb '13 - Dab of Oppo - Gulf1 0554 - 0618 - Feb '13 - Karl K. 0579 - 0619 - May '13 - Laurens - Gulf Empire Kit 0586 - xxxx -May '13 - Cubemark - comfort kit,centa,BB,urban cooling kit, blumels wheel, Supermax, chassis brace.------------SOLD now drives PEMBLETON VSPORT----------------!!! 0661 - xxxx - May '13 - PeteS 0050 - 0050 - May '13 - Naïves 0668 - xxxx - Apr '13 - PeterG - Sold - Centa,NVH,BB,Rectifier-chassis, Spax adj. Comfort 0674 - xxxx - Apr '13 - DocNik 0680 - 0723 - Jul '13 - emiguy 14060 - 0799 - May '13 - Planenut. New Chassis, Empire kit, G56, Centa, Fairbourne screen, steel sprocket 0705 - 0725 - May '13 - Minnemog 0712 - 0793 - Jun '13 - The Seeker 0713 - xxxx - Jun '13 - The Austrian 2018 SOLD 0727 - 0767 - May '13 - Waldemar - CentaComp, NewBB&NVH, ComfortKit, UrbanCoolingKit, HD-rectifier, third rear sprocket, 2 cowl badges, MorganPark Stage_1 with DFO, BraceKit, CamPulleyBeltUpgrade, RearMudguard, SmallTransmissionTunnel-MorganPark, GloveCompartment-MorganPark 0729 - 0763 - Jun '13 - R1NGA (Phil G) - Centa, New Sprocket/Belt, Crank/Cam Pulley Belt 'Upgrade', Rectifier, Empire Wishbones, DIY Fan, G56 Kit+ECU 0740 - 0782 - Jul '13 - CM31 0772 - 0787 - Jul '13 - bobo - comfort kit,centa,BB,urban cooling kit,crankshaft bolt failure/cover smashed 0752 - 0795 - Jul '13 - Rineke (Laurens wife) - Empire Kit 27213 - 0778 - Oct '13 - TimG - Comfort Kit, Steel rear sprocket, latest ECU, replacement chassis, Centa compensator 0758 - 0855 - Aug '13 - Mol - SQUIRLZ 0820 - 2896 - Aug '13 - Olga - Comfort Kit, centa, cooling kit, oil cooler, BB cooler 0825 - 0931 - Sep '13 - P_Dron - Comfort kit, Suplex adjustable front, crankshaft sprocket bolt/timing belt failure, 2 rectifier failures, 1 dead battery. SOLD 0856 - 0919 - Aug '13 - Black Adder 0859 - xxxx - ??? '13 - Zackybilly1 0877 - xxxx - Sep '13 - Smaug - Super Dry 0896 - 0926 - Sep '13 - Bigpoppapump 0901 - 0949 - Sep '13 - kar120c - Sport Blue/Black Leather 0905 - xxxx - Sep '13 - LarryS 0911 - 0906 - Nov '13 - Craig L 0915 Dec 13- George M 0921 - xxxx - Oct '13 - GT Tours Location 0946- HKNYMOG 0948 - 1017 - Nov '13 - Chris99 - Comfort Steering, Urban Cooling, Centra, steel rear sprocket, Stage 1 exhaust kit, Stage 2 cams, ecu and Krazy Horse dyno tune 0969 - 1299 - Oct '13 - Swiss Ghost 0958 - xxxx - Oct '13 - MOG33850 - 2014 modified at factory 1001 - xxxx - Oct '13 - Nippymog 0981 - 2179 - Apr '14 - spelunx 0975 - xxxx - Jul '14 - Owner Unknown vehicle in service 0993 - XXXX - > '13 - Bluebricked, Seattle WA, SuperDry Silver/Mulbury (Urban cooling, KH Steering, G56 Stage 1, SuperDry steering wheel, etc.....and a proper ground surface on the Centa update journal courtesy of 3Gs) 1084 - 1151 - Mar '14 - Stringers Best Mate - Dakota Grey Matte / Black Leather (Sold Feb '16) 1152 - xxxx - Apr '14 - Lotusianer 1171 - xxxx - Apr '14 - alexuels 7234 - 2301 - Feb '15 - Sport Blue/Honey Leather Stage 1 SOLD 9759 - 2312 - Mar '15 - Sportster - Sport Black/Honey Leather 11636 - 2352 - Jun '15 - Mapman - Sport Grey/Scarlet Leather 11214 - 2358 - Jun '15 - PhilipNZ - Dark Grey/Scarlet Leather 15649 - 2431 - January '16 - KenShapiro - WillowGreen/Honey 19146 - 2036 - Apr '16 - Richard Wood - Sport Green/Tan SOLD 20224 - 1299 - Dec 2016 - Brooklands Green/Black leather, C Miller 20259 - 2056 - June '16 - Mark Terlecky - Sport Red/Black 20336 - 2026-Oct '16 - Draggin - Merc. Palladium Silver/Waterproof Saddle XXXX - 2097 - Dec ’16 - Rick Kaufman - Sport Blue/Burnt Orange - USA XXXX -2098- Nov ’16 - Jim Henry - Connaught Green/Honey - USA 22895 - 2099 Nov '16 - Glenn - AM California Sage/Yarwood red leather 24156 - 2123 - Dec '16 - FastKen Cemo - Sport Red/Yarwood Honey -Build 84024 21688 - 2068 - Aug '16 - JoeJoe - Sport Green/Black XXXX - 2083 - Oct '16 - PaulR - Sport Green / Tan / MMC Stage 1 / Krazy Horse Wishbone Kit 2135 - XXXX - Mar 17 - Griff07 - Brooklands Green / Black Leather - Rudenmeister Clocks & Kuryakyn Mach 2 Air Filter 202001-84013 - April '17 - James Lyle-BRG w/Blk leather 202028-84119 - April '17 - Amir Ghorbani- Willow Green Inspired by Peter G. M3W 202039-84182 - April '17 - Chris Bachmann - Sport Green/Honey/Shark/ SF, CA 32859-202020 - April '17 - John Pavone - Sport Black/Mulbury/MMC Stage1 - USA 24622-2011 - Jan '17 - High Noon - military matte green - honey leather 32856-2069 - Sept '17 - Manufactured in June- Grey / Black leather, W Mann, NH USA 37959-2012-June ‘19 Manufacture- Ivory w/honey leather, Seattle USA
Posts: 60 |
under VIN seat ------------------------------------------------------------ 0001 - xxxx - Feb '12 - Aeroman SOLD 0003 - xxxx - Feb '12 - Taffmog -original development car converted in 2013 to the Grim Reaper -UK 0004 - xxxx - Feb '12 - ajsms999 ex SGT DEMO 0006 - xxxx - Feb '12 - KJFB - ex Lifes DEMO 0007 - xxxx - Jan '12 - Melvyn Rutter Ltd - DEMO 0008 - xxxx - Jan '12 - Al1rhd 0009 - xxxx - Jan '12 - CSCC Sweden - DEMO 0013 - xxxx - Jan '12 - 1560 0020 - 2014 - Aug '12 - Thono Germany/Berlin - first registration in sweden ... 0027 - xxxx - Feb '12 - Tomtom 0032 - xxxx - Feb '12 - Herman01 0047 - xxxx - Feb '12 - Vitti4.3W 0049 - xxxx - Feb '12 - Asbojohn 0050 - xxxx - mar '13 - nadvys 0051 - 0051 - mar 12 Grimaud 0070-2011-March 2012 Chocadoodledoo, New Hybrid Chassis and Bodyshell( due to corrosion) in 2016. Plus Centa Drive, Comfort Kit,Urban Cooling Kit, Supermax Sprocket with modified early hub to give belt space. Nov 2019, Bleazey Driveline Conversion and crank oil seal mods. 0083 - 2048 _ Apr ,12 _ Elcyd 0109 - 2067 - Apr ,12 - Hugo ,Centa, chassis brace, comfort kit, rectifier, cam cover, cam bolts, new bearings ,steel sprocket, rear hub, 0125 - 1002 - May '12 - John Winn 0129 - 0092 - Apr '12 - JMD - new chassis/Centa/comfort kit 0130 - 0117 - Mar '12 - donaldosaurus - Convertisseur, Centa 0131 - 0083 - Apr '12 - P964 0133 - xxxx - May '12 - MTW69 0157 - xxxx - May '12 - CSCC Sweden ( ex Stig, now for sale) 0162 - 0107 - May '12 - MDH, (ex Ledgerwoods Demonstrator), Urban Cooling kit, Bonnet Latches, 12/14 Hybrid Chassis, Centa, Re-spray. New 2016 body. Steel drive pulley, Cambelt modification. Stainless cowling. 0189 - xxxx - June '12 - Robby Udine (Italy): upgraded wishbones, Blockley tyres, will have chassis bracing 0200 - 0141 - May '12 - Simmo 0214 - 0162 - Jun '12 - BunnyBoy - Bleazey BB Mount & Centa Mods, Supermax sprocket, G56 Exhaust, Urban Cooling, Welded chassis bracing, Fairbourne Aero screen XXXX - XXXX- aug 12 - X....TR6 0250 - 0240 - Sep '12 - french owner 0326 - 0307 - Jul '12 - Delivered Arizona Oct. 2012 Chassis Brace upgrade, cam belt/bolts upgrade, Fairbourne screens. No other major issues to date. Original owner. TomS 0334 - 0213 - Sep '12 - HJP; April '16 - Tim W 0343 - 0305 - Oct '12 - hbatts 0350 - 0367 - Oct '12 - wis cos 0364 - 0315 - Oct '12 - ArchieWetleg. Sport Green. Written off in rollover accident 14-04-2018 CAT S. If it's ever bought out of salvage and repaired contact me for some photos before you hand over the cash. Both occupants OK apart from dented pride. 0385 - 0337 - Dec '12 - KBMOG 1001 - 0396 - Dec '12 - RedThree - Centa Compensator, Replacement chassis, Replacement chassis, Comfort kit fitted, One dead rectifier, later rear hub, Stage 1 Kit - N.B. This is correct entry! 0401 - 2352 - ??? ‘12 - GPC1203 - The usual upgrades, on its second CE rectifier - Darien, Connecticut, USA 0404 - 0399 - ??? '12 - Mikethetrike 0405 - 0371 - Dec '12 - MichaelH - Comfort Kit, H-D rectifier, Three rear sprockets now SuperMax, exhaust bobbins, front Blockley tires, Centa Compensator, new clutch xxxx - 0449 - Dec. 12 - Jm 0458 - 0458 - Dec '12 - Mi3Wheeler sold to Bitsobrits March 2018 xxxx - 0495 - Jan '13 - rotobug - green/scarlet leather, comfort steering, chassis brace, urban cooling on order________________________ 0491 - xxxx - Feb '13 - CPC 0529 - XXXX - Jan '13 - MTWV2 Xxxx - 0474 - Feb '13 - Max - Superdry Xxxx - 0475 - Feb '13 - Jack - pin exhaust, rear bearings. 0539 - 0485 - Feb '13 - Raphy - Superdry centa /chssis 2015 0541 - xxxx - Feb '13 - Dab of Oppo - Gulf1 0554 - 0618 - Feb '13 - Karl K. 0579 - 0619 - May '13 - Laurens - Gulf Empire Kit 0586 - xxxx -May '13 - Cubemark - comfort kit,centa,BB,urban cooling kit, blumels wheel, Supermax, chassis brace.------------SOLD now drives PEMBLETON VSPORT----------------!!! 0661 - xxxx - May '13 - PeteS 0050 - 0050 - May '13 - Naïves 0668 - xxxx - Apr '13 - PeterG - Sold - Centa,NVH,BB,Rectifier-chassis, Spax adj. Comfort 0674 - xxxx - Apr '13 - DocNik 0680 - 0723 - Jul '13 - emiguy 14060 - 0799 - May '13 - Planenut. New Chassis, Empire kit, G56, Centa, Fairbourne screen, steel sprocket 0705 - 0725 - May '13 - Minnemog 0712 - 0793 - Jun '13 - The Seeker 0713 - xxxx - Jun '13 - The Austrian 2018 SOLD 0727 - 0767 - May '13 - Waldemar - CentaComp, NewBB&NVH, ComfortKit, UrbanCoolingKit, HD-rectifier, third rear sprocket, 2 cowl badges, MorganPark Stage_1 with DFO, BraceKit, CamPulleyBeltUpgrade, RearMudguard, SmallTransmissionTunnel-MorganPark, GloveCompartment-MorganPark 0729 - 0763 - Jun '13 - R1NGA (Phil G) - Centa, New Sprocket/Belt, Crank/Cam Pulley Belt 'Upgrade', Rectifier, Empire Wishbones, DIY Fan, G56 Kit+ECU 0740 - 0782 - Jul '13 - CM31 0772 - 0787 - Jul '13 - bobo - comfort kit,centa,BB,urban cooling kit,crankshaft bolt failure/cover smashed 0752 - 0795 - Jul '13 - Rineke (Laurens wife) - Empire Kit 27213 - 0778 - Oct '13 - TimG - Comfort Kit, Steel rear sprocket, latest ECU, replacement chassis, Centa compensator 0758 - 0855 - Aug '13 - Mol - SQUIRLZ 0820 - 2896 - Aug '13 - Olga - Comfort Kit, centa, cooling kit, oil cooler, BB cooler 0825 - 0931 - Sep '13 - P_Dron - Comfort kit, Suplex adjustable front, crankshaft sprocket bolt/timing belt failure, 2 rectifier failures, 1 dead battery. SOLD 0856 - 0919 - Aug '13 - Black Adder 0859 - xxxx - ??? '13 - Zackybilly1 0877 - xxxx - Sep '13 - Smaug - Super Dry 0896 - 0926 - Sep '13 - Bigpoppapump 0901 - 0949 - Sep '13 - kar120c - Sport Blue/Black Leather 0905 - xxxx - Sep '13 - LarryS 0911 - 0906 - Nov '13 - Craig L 0915 Dec 13- George M 0921 - xxxx - Oct '13 - GT Tours Location 0946- HKNYMOG 0948 - 1017 - Nov '13 - Chris99 - Comfort Steering, Urban Cooling, Centra, steel rear sprocket, Stage 1 exhaust kit, Stage 2 cams, ecu and Krazy Horse dyno tune 0968 1299 - June '14 John E. Brooklands. Bleazey Centa Mods. Fairbourne screen. 0969 - 1299 - Oct '13 - Swiss Ghost 0958 - xxxx - Oct '13 - MOG33850 - 2014 modified at factory 1001 - xxxx - Oct '13 - Nippymog 0981 - 2179 - Apr '14 - spelunx 0975 - xxxx - Jul '14 - Owner Unknown vehicle in service 0993 - XXXX - > '13 - Bluebricked, Seattle WA, SuperDry Silver/Mulbury (Urban cooling, KH Steering, G56 Stage 1, SuperDry steering wheel, etc.....and a proper ground surface on the Centa update journal courtesy of 3Gs) 1084 - 1151 - Mar '14 - Stringers Best Mate - Dakota Grey Matte / Black Leather (Sold Feb '16) 1152 - xxxx - Apr '14 - Lotusianer 1171 - xxxx - Apr '14 - alexuels 7234 - 2301 - Feb '15 - Sport Blue/Honey Leather Stage 1 SOLD 9759 - 2312 - Mar '15 - Sportster - Sport Black/Honey Leather 11636 - 2352 - Jun '15 - Mapman - Sport Grey/Scarlet Leather 11214 - 2358 - Jun '15 - PhilipNZ - Dark Grey/Scarlet Leather 15649 - 2431 - January '16 - KenShapiro - WillowGreen/Honey 19146 - 2036 - Apr '16 - Richard Wood - Sport Green/Tan SOLD 20224 - 1299 - Dec 2016 - Brooklands Green/Black leather, C Miller 20259 - 2056 - June '16 - Mark Terlecky - Sport Red/Black 20336 - 2026-Oct '16 - Draggin - Merc. Palladium Silver/Waterproof Saddle XXXX - 2097 - Dec ’16 - Rick Kaufman - Sport Blue/Burnt Orange - USA XXXX -2098- Nov ’16 - Jim Henry - Connaught Green/Honey - USA 22895 - 2099 Nov '16 - Glenn - AM California Sage/Yarwood red leather 24156 - 2123 - Dec '16 - FastKen Cemo - Sport Red/Yarwood Honey -Build 84024 21688 - 2068 - Aug '16 - JoeJoe - Sport Green/Black XXXX - 2083 - Oct '16 - PaulR - Sport Green / Tan / MMC Stage 1 / Krazy Horse Wishbone Kit 2135 - XXXX - Mar 17 - Griff07 - Brooklands Green / Black Leather - Rudenmeister Clocks & Kuryakyn Mach 2 Air Filter 202001-84013 - April '17 - James Lyle-BRG w/Blk leather 202028-84119 - April '17 - Amir Ghorbani- Willow Green Inspired by Peter G. M3W 202039-84182 - April '17 - Chris Bachmann - Sport Green/Honey/Shark/ SF, CA 32859-202020 - April '17 - John Pavone - Sport Black/Mulbury/MMC Stage1 - USA 24622-2011 - Jan '17 - High Noon - military matte green - honey leather 32856-2069 - Sept '17 - Manufactured in June- Grey / Black leather, W Mann, NH USA 37959-2012-June ‘19 Manufacture- Ivory w/honey leather, Seattle USA
Forum Rules · Mark All ReadContact Us · Talk Morgan
Johnny Vans
Brooklands Edition M3W 1935 F2 2021 Mini Electric
Posts: 1,653 |
under VIN seat ------------------------------------------------------------ 0001 - xxxx - Feb '12 - Aeroman SOLD 0003 - xxxx - Feb '12 - Taffmog -original development car converted in 2013 to the Grim Reaper -UK 0004 - xxxx - Feb '12 - ajsms999 ex SGT DEMO 0006 - xxxx - Feb '12 - KJFB - ex Lifes DEMO 0007 - xxxx - Jan '12 - Melvyn Rutter Ltd - DEMO 0008 - xxxx - Jan '12 - Al1rhd 0009 - xxxx - Jan '12 - CSCC Sweden - DEMO 0013 - xxxx - Jan '12 - 1560 0020 - 2014 - Aug '12 - Thono Germany/Berlin - first registration in sweden ... 0027 - xxxx - Feb '12 - Tomtom 0032 - xxxx - Feb '12 - Herman01 0047 - xxxx - Feb '12 - Vitti4.3W 0049 - xxxx - Feb '12 - Asbojohn 0050 - xxxx - mar '13 - nadvys 0051 - 0051 - mar 12 Grimaud 0070-2011-March 2012 Chocadoodledoo, New Hybrid Chassis and Bodyshell( due to corrosion) in 2016. Plus Centa Drive, Comfort Kit,Urban Cooling Kit, Supermax Sprocket with modified early hub to give belt space. Nov 2019, Bleazey Driveline Conversion and crank oil seal mods. 0083 - 2048 _ Apr ,12 _ Elcyd 0109 - 2067 - Apr ,12 - Hugo ,Centa, chassis brace, comfort kit, rectifier, cam cover, cam bolts, new bearings ,steel sprocket, rear hub, 0125 - 1002 - May '12 - John Winn 0129 - 0092 - Apr '12 - JMD - new chassis/Centa/comfort kit 0130 - 0117 - Mar '12 - donaldosaurus - Convertisseur, Centa 0131 - 0083 - Apr '12 - P964 0133 - xxxx - May '12 - MTW69 0157 - xxxx - May '12 - CSCC Sweden ( ex Stig, now for sale) 0162 - 0107 - May '12 - MDH, (ex Ledgerwoods Demonstrator), Urban Cooling kit, Bonnet Latches, 12/14 Hybrid Chassis, Centa, Re-spray. New 2016 body. Steel drive pulley, Cambelt modification. Stainless cowling. 0189 - xxxx - June '12 - Robby Udine (Italy): upgraded wishbones, Blockley tyres, will have chassis bracing 0200 - 0141 - May '12 - Simmo 0214 - 0162 - Jun '12 - BunnyBoy - Bleazey BB Mount & Centa Mods, Supermax sprocket, G56 Exhaust, Urban Cooling, Welded chassis bracing, Fairbourne Aero screen XXXX - XXXX- aug 12 - X....TR6 0250 - 0240 - Sep '12 - french owner 0326 - 0307 - Jul '12 - Delivered Arizona Oct. 2012 Chassis Brace upgrade, cam belt/bolts upgrade, Fairbourne screens. No other major issues to date. Original owner. TomS 0334 - 0213 - Sep '12 - HJP; April '16 - Tim W 0343 - 0305 - Oct '12 - hbatts 0350 - 0367 - Oct '12 - wis cos 0364 - 0315 - Oct '12 - ArchieWetleg. Sport Green. Written off in rollover accident 14-04-2018 CAT S. If it's ever bought out of salvage and repaired contact me for some photos before you hand over the cash. Both occupants OK apart from dented pride. 0385 - 0337 - Dec '12 - KBMOG 1001 - 0396 - Dec '12 - RedThree - Centa Compensator, Replacement chassis, Replacement chassis, Comfort kit fitted, One dead rectifier, later rear hub, Stage 1 Kit - N.B. This is correct entry! 0401 - 2352 - ??? ‘12 - GPC1203 - The usual upgrades, on its second CE rectifier - Darien, Connecticut, USA 0404 - 0399 - ??? '12 - Mikethetrike 0405 - 0371 - Dec '12 - MichaelH - Comfort Kit, H-D rectifier, Three rear sprockets now SuperMax, exhaust bobbins, front Blockley tires, Centa Compensator, new clutch xxxx - 0449 - Dec. 12 - Jm 0458 - 0458 - Dec '12 - Mi3Wheeler sold to Bitsobrits March 2018 xxxx - 0495 - Jan '13 - rotobug - green/scarlet leather, comfort steering, chassis brace, urban cooling on order________________________ 0491 - xxxx - Feb '13 - CPC 0529 - XXXX - Jan '13 - MTWV2 Xxxx - 0474 - Feb '13 - Max - Superdry Xxxx - 0475 - Feb '13 - Jack - pin exhaust, rear bearings. 0539 - 0485 - Feb '13 - Raphy - Superdry centa /chssis 2015 0541 - xxxx - Feb '13 - Dab of Oppo - Gulf1 0554 - 0618 - Feb '13 - Karl K. 0579 - 0619 - May '13 - Laurens - Gulf Empire Kit 0586 - xxxx -May '13 - Cubemark - comfort kit,centa,BB,urban cooling kit, blumels wheel, Supermax, chassis brace.------------SOLD now drives PEMBLETON VSPORT----------------!!! 0661 - xxxx - May '13 - PeteS 0050 - 0050 - May '13 - Naïves 0668 - xxxx - Apr '13 - PeterG - Sold - Centa,NVH,BB,Rectifier-chassis, Spax adj. Comfort 0674 - xxxx - Apr '13 - DocNik 0680 - 0723 - Jul '13 - emiguy 14060 - 0799 - May '13 - Planenut. New Chassis, Empire kit, G56, Centa, Fairbourne screen, steel sprocket 0705 - 0725 - May '13 - Minnemog 0712 - 0793 - Jun '13 - The Seeker 0713 - xxxx - Jun '13 - The Austrian 2018 SOLD 0727 - 0767 - May '13 - Waldemar - CentaComp, NewBB&NVH, ComfortKit, UrbanCoolingKit, HD-rectifier, third rear sprocket, 2 cowl badges, MorganPark Stage_1 with DFO, BraceKit, CamPulleyBeltUpgrade, RearMudguard, SmallTransmissionTunnel-MorganPark, GloveCompartment-MorganPark 0729 - 0763 - Jun '13 - R1NGA (Phil G) - Centa, New Sprocket/Belt, Crank/Cam Pulley Belt 'Upgrade', Rectifier, Empire Wishbones, DIY Fan, G56 Kit+ECU 0740 - 0782 - Jul '13 - CM31 0772 - 0787 - Jul '13 - bobo - comfort kit,centa,BB,urban cooling kit,crankshaft bolt failure/cover smashed 0752 - 0795 - Jul '13 - Rineke (Laurens wife) - Empire Kit 27213 - 0778 - Oct '13 - TimG - Comfort Kit, Steel rear sprocket, latest ECU, replacement chassis, Centa compensator 0758 - 0855 - Aug '13 - Mol - SQUIRLZ 0820 - 2896 - Aug '13 - Olga - Comfort Kit, centa, cooling kit, oil cooler, BB cooler 0825 - 0931 - Sep '13 - P_Dron - Comfort kit, Suplex adjustable front, crankshaft sprocket bolt/timing belt failure, 2 rectifier failures, 1 dead battery. SOLD 0856 - 0919 - Aug '13 - Black Adder 0859 - xxxx - ??? '13 - Zackybilly1 0877 - xxxx - Sep '13 - Smaug - Super Dry 0896 - 0926 - Sep '13 - Bigpoppapump 0901 - 0949 - Sep '13 - kar120c - Sport Blue/Black Leather 0905 - xxxx - Sep '13 - LarryS 0911 - 0906 - Nov '13 - Craig L 0915 Dec 13- George M 0921 - xxxx - Oct '13 - GT Tours Location 0946- HKNYMOG 0948 - 1017 - Nov '13 - Chris99 - Comfort Steering, Urban Cooling, Centra, steel rear sprocket, Stage 1 exhaust kit, Stage 2 cams, ecu and Krazy Horse dyno tune 0968 1299 - June '14 John E. Brooklands. Bleazey Centa Mods. Fairbourne screen. 0969 - 1299 - Oct '13 - Swiss Ghost 0958 - xxxx - Oct '13 - MOG33850 - 2014 modified at factory 1001 - xxxx - Oct '13 - Nippymog 0981 - 2179 - Apr '14 - spelunx 0975 - xxxx - Jul '14 - Owner Unknown vehicle in service 0993 - XXXX - > '13 - Bluebricked, Seattle WA, SuperDry Silver/Mulbury (Urban cooling, KH Steering, G56 Stage 1, SuperDry steering wheel, etc.....and a proper ground surface on the Centa update journal courtesy of 3Gs) 1084 - 1151 - Mar '14 - Stringers Best Mate - Dakota Grey Matte / Black Leather (Sold Feb '16) 1152 - xxxx - Apr '14 - Lotusianer 1171 - xxxx - Apr '14 - alexuels 7234 - 2301 - Feb '15 - Sport Blue/Honey Leather Stage 1 SOLD 9759 - 2312 - Mar '15 - Sportster - Sport Black/Honey Leather 11636 - 2352 - Jun '15 - Mapman - Sport Grey/Scarlet Leather 11214 - 2358 - Jun '15 - PhilipNZ - Dark Grey/Scarlet Leather 15649 - 2431 - January '16 - KenShapiro - WillowGreen/Honey 19146 - 2036 - Apr '16 - Richard Wood - Sport Green/Tan SOLD 20224 - 1299 - Dec 2016 - Brooklands Green/Black leather, C Miller 20259 - 2056 - June '16 - Mark Terlecky - Sport Red/Black 20336 - 2026-Oct '16 - Draggin - Merc. Palladium Silver/Waterproof Saddle XXXX - 2097 - Dec ’16 - Rick Kaufman - Sport Blue/Burnt Orange - USA XXXX -2098- Nov ’16 - Jim Henry - Connaught Green/Honey - USA 22895 - 2099 Nov '16 - Glenn - AM California Sage/Yarwood red leather 24156 - 2123 - Dec '16 - FastKen Cemo - Sport Red/Yarwood Honey -Build 84024 21688 - 2068 - Aug '16 - JoeJoe - Sport Green/Black XXXX - 2083 - Oct '16 - PaulR - Sport Green / Tan / MMC Stage 1 / Krazy Horse Wishbone Kit 2135 - XXXX - Mar 17 - Griff07 - Brooklands Green / Black Leather - Rudenmeister Clocks & Kuryakyn Mach 2 Air Filter 202001-84013 - April '17 - James Lyle-BRG w/Blk leather 202028-84119 - April '17 - Amir Ghorbani- Willow Green Inspired by Peter G. M3W 202039-84182 - April '17 - Chris Bachmann - Sport Green/Honey/Shark/ SF, CA 32859-202020 - April '17 - John Pavone - Sport Black/Mulbury/MMC Stage1 - USA 24622-2011 - Jan '17 - High Noon - military matte green - honey leather 33193- 2019 - Donaldosaurus, Ferrari Rosso Rubino - Black leather 32856-2069 - Sept '17 - Manufactured in June- Grey / Black leather, W Mann, NH USA 37959-2012-June ‘19 Manufacture- Ivory w/honey leather, Seattle USA
