0 members (),
327
38
Topics49,897
Posts838,017
Posts: 121 Likes: 1
Posts: 121 Likes: 1 |
I ordered the Morgan third brake light stem and light. I went to install it and the stem has a weird thread on it. It is not SAE, Metric, BSF or Whitworth. Does anyone have one of these lights and if so what nut fits the stem. I am beginning to wonder if the poor machining of the stem bled over to poor cutting of the threads?? HELP!!
Posts: 1,625 Likes: 25
Posts: 1,625 Likes: 25 |
Posts: 121 Likes: 1
well a 12mm 1.75 or 1/2" SAE nut fits it. It goes on so far and locks up. So I was told it is a whitworth 1/2" 12. nope. Then a BSF 1/2" 16, nope. I think it is just a faulty part. The BSF goes on and will get the entire nut started then locks up. This is a Morgan part. I will tried the 10 but it won't go on the stem. For what they charge for this, they should've sent the nut with the stem
Posts: 1,738 Likes: 56
Posts: 1,738 Likes: 56 |
I've just checked mine and it is indeed a regular M12 1.75 thread and a nut can be easily threaded on - so I suspect that the thread on yours hasn't been cut properly.
Andy
Posts: 121 Likes: 1
Thank you for going through the trouble for me
Posts: 8,696 Likes: 416
Posts: 8,696 Likes: 416 |
M12 is available with 1, 1.25, 1.5 and 1.75 mm pitch. Measuring the pitch over say ten thread peaks with vernier calipers then dividing will tell you the actual pitch on your stalk, if that helps. You can also confirm the thread major diameter which will likely be a tad less than 12mm for M12.
Posts: 121 Likes: 1
I counted 16 threads per inch. What pitch does that make it ?
16 TPI is a pitch of 0.0625 inches or 1.587 mm
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
I counted 16 threads per inch. What pitch does that make it ? 16 threads in 25.4mm suggests a thread pitch of 25.4/16 = 1.58 so allowing for error in measurement a 1.5mm pitch
Posts: 2,119 Likes: 70
Posts: 2,119 Likes: 70 |
A tip on the side, as questions about thread pitches are always asked here: A very usefull and inexpensive tool is a thread gauge. Here a photo Thread gauge![[Linked Image]](https://i.ebayimg.com/images/g/vDsAAOSwj8FfZG3C/s-l400.jpg)
