7 members (uvk33n, JMcL, Luddite, Franko, IcePack, jbk, Mogdavid),
328
33
Topics49,916
Posts838,221
Posts: 12,269 Likes: 324
Posts: 12,269 Likes: 324 |
Chuck the filter, and try again. Don't be daft, man! You can't put unfiltered electricity into a small-capacity engine like that, the bits will be too big and lead to lumpy running.
Posts: 7,435 Likes: 122
Posts: 7,435 Likes: 122 |
Is that a fusion space ship engine?
Posts: 1,799 Likes: 4
Posts: 1,799 Likes: 4 |
I'm not sure what other forums will make of this.
They will probably take all your responses literally and what will that do for TM's reputation.
Bob
Posts: 2,583 |
I have the same problem getting started. I`m told it`s the cold weather. Thankfully the Morgan starts at the first turn of the key.
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
It may affect the power band, so I've popped another in the post..
Posts: 1,065 Likes: 23
Posts: 1,065 Likes: 23 |
A joke in my youth.... tell a bloke „undo the spark plug. That grows up the combustion chamber and give a bigger explosion for more power with every rev...“
So clear: a filter helps to sort bad ignitions! a helpful tool.
Greets René
2018 plus4 (sports green) with a homemade really shiny red tinted dash…
Posts: 2,822 Likes: 155
Posts: 2,822 Likes: 155 |
Sure it's not a diesel...in which case the filter should be on the glow plug side of the spark plug.
Posts: 11,536 Likes: 321
Posts: 11,536 Likes: 321 |
I would check for a poor ground connection as it appears to be missing.
Posts: 2,121 Likes: 71
Posts: 2,121 Likes: 71 |
Important is to have a look wether there is a mark/ arrow for the direction on the filter?
Posts: 939 Likes: 46
Posts: 939 Likes: 46 |
With that kind of new filter only 5G transmitted sparks arrive with the correct temperature. The classic analogue sparks are filtered, as I understood,.,
1973 2CV AK400 Ralley 1985 plus 4 four seater 1992 Peraves ecomobil bicycles (pedersen to recumbent)
