3 members (Graham, G4FUJ, dakri, Montegue), 158 guests, and 49 robots.
+8Rich 95
John V6 52
Posts838,013
rockabilly john
Page 4 of 4 1 2 3 4
Originally Posted by Hogzilla
Everything is higher than the Three Wheeler so unless you want height to try and get above luggage it can easily be seen. Here is a view from the ground, and unless i just ran over you it is a view that never would be seen.
What exhaust do you have on your 3 wheeler?
AR from MMC in New England.
Originally Posted by Piloto
If you are interested in a totally cool third brake light, check out the Grimes model B aircraft wing light on Univair Aircraft Supply's website. I dug around my old parts box and came up with one, red lens. I will be installing it on a machined aluminum (or aluminium, depending of your location) mount, and using an LED bulb in place of the incandescent one.
I believe it fits the Morgan quite rightly.
Best,
tom
Those sure are expensive and that flimsy bale might go adrift and another expensive part fall to the ground and break. The general looks is nice.
45 bucks on fleabay. Used them years ago as original equipment on a Waco biplane with a "Shaky Jake" 300 horse radial engine. Plenty of vibes, and acro to +5 and -2 G's; the wire on the lens never budged.
Sure liked your exhaust tone. Can you be more specific about the type of muffler, and the supplier?
Thank you,
Tom
Best,
tom
Thank you,
Tom
Tom, the mufflers i use are the MMC AERO RACING (AR) from Morgan New England. Commonly referred to as AR Stage 1 mufflers.
Thank you, Stephen. I will contact them. With luck, I'll get to meet you this summer, as I am looking for work as an A&P mechanic at Kenmore Air Harbor.
Regards,
Tom
Hope it works out for you. Kenmore Air lands in front of my home and taxis over to the local marina on occasion, mostly during the summer.
Page 4 of 4 1 2 3 4
