5 members (Plus Four Guy, vincentvg, DavidR, Laurens, Ian Wegg), 167 guests, and 50 robots.
Luddite 50
Posts837,950
#688573 13/02/21 12:37 PM
Black Rat
Black Rat
Battery has died on my 2013 Plus 4 does anybody know what the battery is please ?
Keith
2013 narrow bodied + 4 Ruby.
Burgundymog #688580 13/02/21 01:10 PM
It's the big box behind the seats under the luggage compartment. innocent
Regards
Alan
AP08 MOG
Great!
Kevin
2009 Morgan Plus 4 - 4 seater
2015 Subaru Forester 2.0ltr
Burgundymog #688586 13/02/21 01:34 PM
Plus 8 here so can't help - maybe it's in DW's book if you have a copy ?
Someone helpful will be along soon if not. gomog advice I normally take mine out so I'm sure and get a direct electrical and physical replacement, sounds simple but it's not always. I've never been let down at my local motor factors doing it this way. It's easily doable from the top with caution.
Good luck.
Burgundymog #688588 13/02/21 01:47 PM
Black Rat
Black Rat
Cain is sending me the details, apparently it's a Banner.
Keith
Burgundymog #688597 13/02/21 02:06 PM
If from new it's probably a Banner 50200 Unibull. I don't think these are available anymore though.
Burgundymog #688602 13/02/21 02:13 PM
Simply measure it’s physical size, note the ampere hour capacity and cold cranking amps, which will be shown on the battery label, the type of terminal whether round or flat and then pop along to halfords for an equivalent one at a reasonable price.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Burgundymog #688606 13/02/21 02:35 PM
Having checked on Tayna Batteries an equivalent to the Banner size wise is a ENDUROLINE
https://www.tayna.co.uk/car-batteries/enduroline/075/
Burgundymog #688607 13/02/21 02:48 PM
Hi,
I would be surprised if your battery cradle, the size of which determines the physical size of battery that can be fitted, is different to mine which accommodated a Banner 50 200 (no longer available).
When mine, died I replaced with a Banner 075 / P6352.
Exactly the same dimensions but higher cranking.
If you don’t want to go into any shops Tayna Batteries will deliver to you within a couple of days, great service. I have no connection
Regards
Geof
70th Anniversary 4/4 (Duratec 1.8), model 1995
Burgundymog #688609 13/02/21 03:00 PM
I've used Tayna before to supply batteries and it's worked fine and they've been quick and easy to deal with ..... one thing I'd check is the warranty given ....I recently bought some big Rolls renewable energy batteries .... 7 year warranty .... but when I checked Tayna as their prices are usually very good, they were only giving a 1 year warranty .... either they're buying them from Rolls without warranty and therefore cheaper .. or giving a 1 year warranty on something they're getting a 7 year warranty on from the manufacturer. I bought elsewhere slightly more expensive to get the full warranty in this case.
