5 members (TBM, DalesPlusFour, Hamwich, Julian BB, Mike D), 338 guests, and 30 robots.
+8Rich 102
John V6 59
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,914
Posts838,173
Georgetoad, woolfie
#689108 16/02/21 02:58 PM
B3MOG Offline OP
I require a new steering rack gaitor for a 1985 +8 (jack knight st. rack) someone suggested using a Borg+Beck BSG3190 that is fitted to a Saab 900. has anybody tried using this gaitor?
David Byrne
Hi David. I replaced them on my 1999 Plus8 last summer which presumably has the same rack ? I was told that MAPCO 17753 bellows also fit, but I just got a kit from SimonH at Simon @ Sifab.co.uk who is on this forum and was very helpful. (No connection) I found the most difficult job was persuading the lower steering column joint off the racks input drive spline. I removed the pinch bolt and carefully knocked in a wedge to expand the joint, not forgetting to paint a witness mark to allow correct realignment on rebuild. Hope that helps ?
John Adams.
As you ought to replace the weird shaped locking tab washer you may as well buy the proper gaiter too, most decent Mog dealers seem to keep a couple in stock as they are a fairly regular MOT failure
B3MOG Offline OP
Thanks for the reply, I am getting the kit from Sifab, once again Simon is a big help.
David Byrne.
P.S. this is the first time it has been changed in 36yrs.
Thats a fact sadly, and given the price of the flimsy things, I'm glad I found SimonH's, unfortunately just after I'd already bought the JK original from a dealer
06 Saab 93
If you're talking about the gaiter for the Jack Knight steering racks, they are a fairly regular MOT failure because the quality is cr+p! Someone is making a killing at around £100 a pop, fitting extra, + VAT! My 1994 +8 is still on it's first gaiter. My 2002 4/4 is on it's 5th. That doesn't seem like consistent quality over the years to me.
1994 +8, BMW Calypso Red.
How do you open the boot?
Whatever one used lubricate well with grease before fitting. Helps avoid accidental ripping on installation.
The Factory uses Morris lubricants K400EP semi-fluid grease.
PM sent re photos.
Quite so, mine went just after the MOT seemingly, and I thought it had to be replaced with a Morgan JK gaiter, so paid the money- then I found Simons with the adapters at around a third the price, so I have an original spare now, just in case I feel like going concourse I suppose!
06 Saab 93
