7 members (BobtheTrain, Hamwich, AlyMatt, RichardV6, TBM, DalesPlusFour, Ruut Bianchi),
279
Topics49,914
Posts838,174
Posts: 520 Likes: 62
Posts: 520 Likes: 62 |
I require a new steering rack gaitor for a 1985 +8 (jack knight st. rack) someone suggested using a Borg+Beck BSG3190 that is fitted to a Saab 900. has anybody tried using this gaitor?
David Byrne
Posts: 122 |
Hi David. I replaced them on my 1999 Plus8 last summer which presumably has the same rack ? I was told that MAPCO 17753 bellows also fit, but I just got a kit from SimonH at Simon @ Sifab.co.uk who is on this forum and was very helpful. (No connection) I found the most difficult job was persuading the lower steering column joint off the racks input drive spline. I removed the pinch bolt and carefully knocked in a wedge to expand the joint, not forgetting to paint a witness mark to allow correct realignment on rebuild. Hope that helps ?
John Adams.
Posts: 8,703 Likes: 501
Posts: 8,703 Likes: 501 |
As you ought to replace the weird shaped locking tab washer you may as well buy the proper gaiter too, most decent Mog dealers seem to keep a couple in stock as they are a fairly regular MOT failure
Thanks for the reply, I am getting the kit from Sifab, once again Simon is a big help.
David Byrne.
P.S. this is the first time it has been changed in 36yrs.
Posts: 586 Likes: 21
Posts: 586 Likes: 21 |
they are a fairly regular MOT failure Thats a fact sadly, and given the price of the flimsy things, I'm glad I found SimonH's, unfortunately just after I'd already bought the JK original from a dealer
"DOT" 35th Anniversary Edition Plus 8- family owned from new. Rolls Royce Pewter. 06 Saab 93
Posts: 310 Likes: 9
Posts: 310 Likes: 9 |
As you ought to replace the weird shaped locking tab washer you may as well buy the proper gaiter too, most decent Mog dealers seem to keep a couple in stock as they are a fairly regular MOT failure If you're talking about the gaiter for the Jack Knight steering racks, they are a fairly regular MOT failure because the quality is cr+p! Someone is making a killing at around £100 a pop, fitting extra, + VAT! My 1994 +8 is still on it's first gaiter. My 2002 4/4 is on it's 5th. That doesn't seem like consistent quality over the years to me.
1994 +8, BMW Calypso Red. 2002 4/4, 4 seater, BMW Calypso Red. How do you open the boot?
Posts: 220 Likes: 4
Posts: 220 Likes: 4 |
Whatever one used lubricate well with grease before fitting. Helps avoid accidental ripping on installation.
Posts: 310 Likes: 9
The Factory uses Morris lubricants K400EP semi-fluid grease.
Posts: 122 |
As you ought to replace the weird shaped locking tab washer you may as well buy the proper gaiter too, most decent Mog dealers seem to keep a couple in stock as they are a fairly regular MOT failure If you're talking about the gaiter for the Jack Knight steering racks, they are a fairly regular MOT failure because the quality is cr+p! Someone is making a killing at around £100 a pop, fitting extra, + VAT! My 1994 +8 is still on it's first gaiter. My 2002 4/4 is on it's 5th. That doesn't seem like consistent quality over the years to me. Quite so, mine went just after the MOT seemingly, and I thought it had to be replaced with a Morgan JK gaiter, so paid the money- then I found Simons with the adapters at around a third the price, so I have an original spare now, just in case I feel like going concourse I suppose!
