Topics49,911
Posts838,154
Posts: 243 |
Yes, you're right t's a snapshot and during my journey it was move between 3,8 and 4,4 l/100 km never above ... It's so frugal than it's more probably liter/40 km that per 100 km ...  when I will fill in I will have an exact idea of the average.
Posts: 243 |
After 400 km of country road with time to time some hard acceleration I fill the tank up at maximum : 29 liters ! which gives a more than honest average of less than 7.5 liters per 100 km  BUT I also found out that when you turn the wheels at maximum to the left while the suspension is a bit in compression the internal face of the wheel rubs somewhere ...
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
I might be wrong but it looks like on the Plus Four the miles per gallon figure isnβt a cumulative or journey figure but rather a snapshot at the time you look at it, which is a bit of a shame ie it is only based on how much youβre pressing the throttle at that time...I donβt know if it is the same on the Plus Six....I havenβt worked out yet if I can change it so it reflects the period for a whole journey or the average as such. HB Be careful what you wish for.. The C63 will show mog per journey or instant MPG. On 2 mile trip yesterday morning it achieved 11.6mpg. It isn't good when cold... Oh yes, that is with 98 Octane, which Mercedes mandate...
Posts: 1,360 Likes: 5
Posts: 1,360 Likes: 5 |
Thatβs coz you drove like a yoof! Who do you think you are-Sterling Moss? π€£ HB
Plus Four Bentley Velvet Red βGrandi Pβ Golf ehybrid thingy βToadieβ Polestar 4 βVgerβ
Posts: 28,912 Likes: 354
Posts: 28,912 Likes: 354 |
Be careful what you wish for.. The C63 will show mog per journey or instant MPG. On 2 mile trip yesterday morning it achieved 11.6mpg. And I thought the Saab was bad at a little over 22 mpg on the last full tank (first fill on Monday since mid-December). Normal Malvern commute works out at around 37...
Posts: 11,535 Likes: 321
Posts: 11,535 Likes: 321 |
11.6? I cannot even get the barn shaped ML63s that low unless I live on the throttle and brakes permanently. Are you pulling a concrete block or something?
Posts: 1,959 Likes: 15
Posts: 1,959 Likes: 15 |
11.6? I cannot even get the barn shaped ML63s that low unless I live on the throttle and brakes permanently. Are you pulling a concrete block or something? You need to try harder Alistair, I often get single figures out of the Alfa.
in a short distance I can get single figures easily enough but over any distance it has three issues.
1. Law 2. Other road users 3. Corners
They may be in a different order from time to time (2 and 3 clearly)
I will make more effort.
11.6? I cannot even get the barn shaped ML63s that low unless I live on the throttle and brakes permanently. Are you pulling a concrete block or something? Three requirements: 1. Ambient temperature just above freezing 2. Drive 1.2 miles at between 10 and 30 mph including a hill at 15mph... 3. Let the car cool for an hour before repeating 2. On a longer run I've seen 28mpg, yet to crack 30. The C43 will easily show 35, on a long, legally compliant run.
Posts: 215 |
My AMG SLC43 was averaging 7.5 mpg when I was only using it to go to the station & back. Motorway cruising at 90mph ( in Germany obviously) returns 32mpg.
Worst cost is front tyres - six months of the multi storey carpark corners & the mercedes crabbing problem means a set of fronts only last a couple of thousand miles.
