5 members (TBM, John Winn, jbk, Graham, G4FUJ, Oliemog), 426 guests, and 42 robots.
+8Rich 101
John V6 63
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,915
Posts838,210
Georgetoad, woolfie
bear65 Offline OP
Hi Everyone, anyone :-)
I have a m3w and everything has been fine.
Today however, this happened:
Turned Key off & on again three times ( as usual ) started car, all good.
Got to the ferry near where I live, tried to switch the ignition off, car carried on running.
Stalled the car to stop the engine, car started fine, off I go.
Same thing happened when I got to work. Started car using Starter Button and Hazard lights came on so I thought I'd drive straight home as the engine was all good, no overheating etc.
Hazard lights e tried turning on the ignition to hear / engage the fuel pump noise, but nothing but Hazard lights coming on.
Now I don't hear the fuel pump noise when turning on the ignition for ' pre start routine " - Any advice gaudy appreciated.
2016 M3W
1937 AJS 26s combination
1928 Rudge Special
Craig
I would suggest that you re-post this in the M3W forum as the Three Wheeler experts may not spot it here.
This sounds like a sticking ignition relay????
It is likely to be the indicator module, a lot of feeds seem to go through this, check out this thread page 2 onwards
http://www.talkmorgan.com/ubbthreads.php/topics/517471/re-near-side-indicator-issue#Post517471
Excerpt below
"I had a problem with the full beam which could not be switched on. The dealer thought it was a wiring problem but could not find the fault. They tried a new indicator assembly but the fault was still there
On my way to the MTWC opening run the hazard warning lights came on, all the lights on the dashbord lit up and when I tried to switch off the engine it kept running with the key out of the ignition!
The M3W was driven to the hotel where the only way to stop the engine was to stall it and after that it would not start
Skullmog spent over 2 hours on the Saturday evening trying to find the problem and after ruling out fuses, relays, immobiliser and ECU he thought it was the cambus. Thanks again Kevin for your help
The vehicle was trailered back to the dealer and 4.5 weeks later was fixed, the problem being the indicator module unit. On the invoice it was shown as M3W TURN SIGNAL HEADLAMP MODULE and was £39.89 plus VAT
The old part was given to Skullmog for him to look at
At the time we, the MTWC, did not know of anyone else having a problem with this unit"
There have been a number of other instance since.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
+1 - Rog types quicker than I do.................
Red Leader drive
bear65 Offline OP
Thanks
But been struggling to find out how you actually choose a forum then post
2016 M3W
1928 Rudge Special
bear65 Offline OP
Massive thanks everyone
2016 M3W
1928 Rudge Special
bear65 Offline OP
Thanks Dave
2016 M3W
1928 Rudge Special
The indicator module on that vehicle was replaced a year ago after it burnt out.
+1 Indicator relay, i had exactly the same symptoms on my car.
2015 +4 and 2000 4\4
1981 Lambretta GP225
1960 Lambretta LI 125
