6 members (RJW, mph, Colin_Mackay, nestor59310, TalkMorgan, jbk), 251 guests, and 29 robots.
+8Rich 101
John V6 65
Suspension upgrades
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,918
Posts838,259
Smed., Spanner Juggler
Page 2 of 4 1 2 3 4
Mine will drip a few drops when parked then after a week or two it will cease dripping & will be fine for a variable period, no pattern to it. I was never worth correcting & as Calum says the new one will likely do the same.
Hi Tim, thats how mine started, now it's loosing a teaspoon every day just sat in the garage on stands.
The leaking oil has done a fair job of inhibiting any corrosion on the underside though.
Funnily it never dripped a drop of oil in 6 years then after I had the cams changed in 2019 it started to leak and has slowly got worse.
Did you install any breather system when you added the cams?
Originally Posted by Felix42
What with covid restrictions do we want Mexican seals in this country? And what about dophins. irked
I'll take the bait
Rodger
2004 Plus 8 (wife's)
No, dealer did the cams, stock breather system.
I have now modified the breather hose so it has a continuous fall to the engine.
Let us know if that helped with the weepy seal, please.
Will do, although she won't be on the road for another month or so.
Just a quick question guys.
How is everybody stopping the crank shaft from rotating when tightening up the front pulley bolt?
I slackened it off using a windy gun and don't really want to put it on the same way.
Put it in gear.
Hand brake on.
Here are the S&S instructions:
https://www.sscycle.com/docs/defaul...n_shaft_repair_kit_20141211.pdf?sfvrsn=2
The inference is you just tighten it against the cam belt, I can't remember how I did mine but it hasn't moved in 6 years.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
Page 2 of 4 1 2 3 4
