4 members (bmgermany, Morganmike, +8Rich, Strathaven), 219 guests, and 28 robots.
+8Rich 99
John V6 57
Topics49,909
Posts838,126
Steve19 Offline OP
Good afternoon, i need to replace my front indicator lights, any one know who is the original supplier? I need them with the electrical pigtail included.
thanks
Steve Grisdale
Morgan 3.0l Roadster 2010 aka BORIS
Triumph Thunderbird 2000
Volvo XC 60 x 3
Volvo C30
Try Holden Vintage and Classic
https://www.holden.co.uk/
Or Stafford Vehicle Components
https://www.s-v-c.co.uk/
Hi Steve,
If you want to google.....
The orange front indicator lense on my car is stamped L794.
The bulb holder is stamped L794/L795.
To add to Scrambledsignals (both of whom are good) add .......
http://www.leacyclassics.com/lulpb160.html
https://www.autoelectricsupplies.co.uk/product/906/category/135
Hope this helps. Is it magic?
Regards
Geof
70th Anniversary 4/4 (Duratec 1.8), model 1995
X
X
Hi Steve,
I see your trouble about the indicator. Are you shure it‘s the indicator?
A test is a simple DIY.
You need: a glass of wine, cup of tea/coffee or a beer.
comfort seat
A screwdriver, a small spanner
And a tool like this:
https://www.louis.de/artikel/pruefl...1aa90&filter_article_number=10003022
Undo the orange glas and the bulb. Have a drink. Switch on the hazard.
Clip the tool at the chrome. Keep attention and hit the contact in the middle of the fibrewasher with the needle.
The tool flashes? A problem with the spring in the indicator.
No flash?
Undo the nuts of the indicator in the wing. Pull the indicator out and out of the rubber gaiter. Now have a drink and think about
LUCAS the god of Electric darkness.
You see two „bullet connectors“ in loops. Use the tool. Clamp it to one loop and hit the other with the needle scrap a little.
The tool flashes? The loops or bullets look worn?
2018 plus4 (sports green)
X
X
No flash, bullets look worn/dirty/ rusty?
Clean them. Pull them out of the loop, pull the wire out of the loop.
Wires out of the bullets. Do the test again directly at the wires. The tool flashes?
Wonderful. Clean the loops, clean the bullets an fit again. Put the bulb in, it must flash.
If no flash at the wires. Short them and test again. No flash?
Look at the connector in the wing. Unconnect it. Test the connector from the car. Put a needle in one hole and cramp it with the tool. The other hole hit with the tools needle. The tool flashes?
Than the problem is in the connector or the wire to the indicator. The tool doesn‘t flash? The problem ist in the connector.
Usual Procedere in all british cars.
Greets René
Standard LUCAS items, generally available.
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Instead of replacing the whole light unit, you could just make up some new fibre washers to fit the current lights. Push the wire through from the rear and the duff washer should be removable.
pre 2014 the Lucas L691 indicator lamps with pointed lens were used front and rear on Classics. Later models used a different L794 lamp on the front only, with deeper flat face lens allowing an integral reflector. L691 available below.
Hi Richard,
I’ll bow to your depth of knowledge on all things electrical but........
In addition to my bulb holder stamped L794/L795 it is also stamped L691/L692.
The lense is stamped L794 with reflector and not a ring type refraction (is that right?) as shown above
My car is a 2006 build so have I misunderstood?
Regards
Geof
Steve19 Offline OP
Hi Salmo thats the one
Steve Grisdale
Volvo XC 60 x 3
Volvo C30
