9 members (GrumpyPa, RichardV6, JohnHarris, +8Rich, John V6, IcePack, Chris Cosher, Graham, G4FUJ, MartinB60),
258
38
Topics49,904
Posts838,094
Posts: 4,612 Likes: 15
Posts: 4,612 Likes: 15 |
A very timely tread. It was a few weeks ago that on JohnV6 recommendation I tried to purchase LED bulbs from Duncan @ www.classiccarleds.co.uk. There were none in stock and Duncan replied to say that they would be in at the begining of February. So it would seem that I may have saved myself a few £s by not being able to purchase them. I like JohnV6 I have had 1/2 moon LEDs as side lights and nightbreaker H4s on my headlights on my 4/4 with no issue. I also have a pair of CIBIE spot that come on as main beam, fitted with nightbreakers. I was considering changing these to LEDs. Oh well.
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
We need somebody to commission some 7"bowls designed for LED bulbs.
Posts: 3,881 Likes: 402
Posts: 3,881 Likes: 402 |
22 Plus Four KIMI 12 Plus 4 Sport OZZY 08 Roadster FELIX 06 4/4 70th LOKI 77 4/4 SEAMUS 85 4/4 MOLLY
Posts: 27,842 Likes: 764
Posts: 27,842 Likes: 764 |
But you have to ask why didn't someone do that already?
Posts: 8,701 Likes: 501
Posts: 8,701 Likes: 501 |
But you have to ask why didn't someone do that already? Perhaps because there was no need, I've run LED's in OE bowls for around 3yrs without any issues, but now with this latest MOT revision we're a bit stuffed I've spotted several Mogs fitted with angel eyes & other alternative bling headlamps that aren't CE marked that don't seem to get rejected at MOT time
I think those may be sealed beam Heinz, so not a solution for those of us sitting on LED bulbs and needing just the bowls. Although they may be bowls plus bulbs, the cost is eyewatering for such low use.
On second reading it does say "his bulbs" so maybe the bowls are available without bulbs........
Posts: 586 Likes: 21
Posts: 586 Likes: 21 |
These also seem to be current MOT compliant headlights https://www.wolfperformance.co.uk/lights.html
"DOT" 35th Anniversary Edition Plus 8- family owned from new. Rolls Royce Pewter. 06 Saab 93
Posts: 8,699 Likes: 416
Posts: 8,699 Likes: 416 |
We need somebody to commission some 7"bowls designed for LED bulbs. I can see the enthusiasm for a traditional looking headlamp bowl Dave, but it seems unlikely any manufacturer would entertain such given most sealed LED headlamp units are designed, tested and approved/E marked as an integrated unit, more often than not with accurate projector optics for the dipped beam aspect. Furthermore there seem to be an increasing range of compliant sealed units, some of which MMC use themselves on the CX range, and prices are reducing. Land Rover units plus the ones that Wolf and KH are now offering come to mind.
