7 members (MATTMOG, Hamwich, How, BLUE+4, Colin_Mackay, RJW, mph),
238
Topics49,918
Posts838,260
Posts: 1,947 |
Mine will drip a few drops when parked then after a week or two it will cease dripping & will be fine for a variable period, no pattern to it. I was never worth correcting & as Calum says the new one will likely do the same.
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
Hi Tim, thats how mine started, now it's loosing a teaspoon every day just sat in the garage on stands.
The leaking oil has done a fair job of inhibiting any corrosion on the underside though.
Funnily it never dripped a drop of oil in 6 years then after I had the cams changed in 2019 it started to leak and has slowly got worse.
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Did you install any breather system when you added the cams?
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
What with covid restrictions do we want Mexican seals in this country? And what about dophins. I'll take the bait
No, dealer did the cams, stock breather system.
I have now modified the breather hose so it has a continuous fall to the engine.
I have now modified the breather hose so it has a continuous fall to the engine. Let us know if that helped with the weepy seal, please.
Will do, although she won't be on the road for another month or so.
Just a quick question guys.
How is everybody stopping the crank shaft from rotating when tightening up the front pulley bolt?
I slackened it off using a windy gun and don't really want to put it on the same way.
Put it in gear. Hand brake on.
Posts: 1,625 Likes: 25
Posts: 1,625 Likes: 25 |
Here are the S&S instructions: https://www.sscycle.com/docs/defaul...n_shaft_repair_kit_20141211.pdf?sfvrsn=2The inference is you just tighten it against the cam belt, I can't remember how I did mine but it hasn't moved in 6 years.
