4 members (DaveW, cerealsurfer, sewin, zaba), 174 guests, and 69 robots.
+8Rich 70
by +8Rich - 07/09/26 06:43 AM
Some real stars on here
by +8Rich - 07/09/26 02:42 AM
European Bike Week
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,883
Posts837,819
Gyp
#696992 03/04/21 04:17 AM
[img]https://www.dropbox.com/s/da2zq9h2jgxbfzy/IMG_2632.jpg?dl=0[/img]
One of the bars on my grill has become dislodged, any ideas how these are held in place?
Kind regards
The bars are welded to the frame of the grill.
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
Yes, if you know a good local welder you ok, The important word is GOOD!
Otherwise if the repair can be hidden I would look at some of the modern glues on the market. Be interesting to know how it broke.
Navy Dave
1976 Morgan 4/4
That's providing the grill is made of stainless steel, if it's made of brass it's a different game. in that case I think I would the drill the very end of the bar where it sits under the cowl and rivet it. Otherwise it could get very expensive in re-soldering the grill bar and having to re-plate the whole grill
Owen
"bilibib"
1982 4/4 Twin Cam, Royal Ivory
1932 Super Sports, Duo tone(two tone)Green
TBM Offline
For a quick/cheap hidden fix, I'd pack the top section of the bar with some good epoxy like JB Weld, then drill and stick a small self tapper in from the back of the top plate.
You don't say how old the Mog is, if it's Nov18 when you joined, get a warranty claim in quick
It’s a 2010 roadster
https://www.dropbox.com/s/lqaer8ua03hr79z/IMG_2631.jpg?dl=0
Many thanks for your help.
You may be correct but I always thought they were soldered in place . I think there is a big risk of distortion with welding.
Andy G
1999 +8 , Indigo Blue.
Hi there,
I agree with Owen's solution:
Several of mine went that way. Welding seemed risky as the metal of the grille is chromed and very soft on my 1996 4/4: it's brass I suspect. Therefore, as the top section of the grille disappears behind the cowl when installed, I carefully drilled a few tiny 3mm holes into the loose bars and fixed them to the frame of the grille using 3mm aluminum blind rivets. Problem solved for a foreseeable eternity - and the fix is absolutely invisible from the outside.
Cheers
Mich
4/4 1996 1.8 ZETEC Silvertop It has Swivel Pivots and an amazing Umbrella Holder!
When I last had mine out, the stainless looked like it was held with tiny spot welds
