6 members (Lance, bmgermany, cerealsurfer, Graham, G4FUJ, TBM, JMcL),
195
Topics49,909
Posts838,126
Posts: 28,911 Likes: 354
Posts: 28,911 Likes: 354 |
I assume, when you do a test in the mornings that you check whether there is any reduction in the level in the reservoir?
Posts: 990 |
Of course if the engine or gearbox has got to come out to change the slave, a good inspection of the clutch is needed- maybe pop a new one in at the same time while its dismantled.. I think i would. Daves suggestion to do both slave and master cylinders at the same time is very sound advice - if not done chances are the old component will soon fail. Stress caused by the new component being the reason.
All very involved when a clutch slave is ideally fitted along side the gearbox with 2 bolts holding it on - need an MGB for such simplicity!
2015 Morgan 4/4 (Wolf fettled) previously 2014 M3W MINI Cooper S and numerous BMC/BL relics.
