11 members (CooperMan, DaveW, +8Rich, RedThree, Morganmike, TalkMorgan, cerealsurfer, Graham, G4FUJ, John Winn, John Wilcox, Beard),
169
78
Topics49,881
Posts837,792
Posts: 7,342 Likes: 49
Posts: 7,342 Likes: 49 |
There is a difference between the ground clearance on flat ground and what happens at either end when the gradient changes. You can hit a 9cm sleeping policeman with a 10cm ground clearance if the overhangs front and back of the wheels are flat. Spot on Howard. Most jurisdictions have a specification for a vehicle moving over a ramp set at a specific approach and departure angle for that very reason. This spec also sits with the usual100mm flat ground clearance and you will need every bit of that for normal road driving as you rightly point out.
Posts: 4,654 Likes: 124
Posts: 4,654 Likes: 124 |
Anybody know if the P4/P6 needs a protector for the sump like the Aero or have they designed it a bit better so it's not as vulnerable?
2021 Lapis Blue Plus 6  You know it makes sense!  2016 Carmine Red 991.2 C4S
Posts: 82 Likes: 1
Posts: 82 Likes: 1 |
Fully covered under the car.
Heron Grey Plus Four 2021
Previous:- Connaught Green 4/4 1988 Black Plus 8 1998
Posts: 88 Likes: 1
Posts: 88 Likes: 1 |
The exhaust appears to be the lowest point between the wheels.
Mike 1982 4/4 1999 +4 2004 Roadster S1 2010 Roadster S2 2021 Plus 6
Anyone know what the ground clearance should be on a new Plus Four? What is the lowest point? 13 replies and 736 views but we still don't have a specification.....
Posts: 37,445 Likes: 984
Posts: 37,445 Likes: 984 |
Anyone know what the ground clearance should be on a new Plus Four? What is the lowest point? 13 replies and 736 views but we still don't have a specification..... I seem to recall one of our European members saying his Plus Four was 90mm measured at the rear silencer box, he commented how low this was at the time. It will be a problem on slopes for sure.
Posts: 665 Likes: 31
Posts: 665 Likes: 31 |
That's what it is - not what It's supposed to be I suspect....
here is a screen shot from a video on you tube :https://www.dropbox.com/s/30eqfaobj73cd2i/morgan%20plus%20four.JPG?dl=0
Posts: 3,826 Likes: 69
Posts: 3,826 Likes: 69 |
That looks very low to me. I've been struggling with clearance issues lately. It seems to me that the last Mogs with 5inches or so clearance were just before the long door models, so mid 90s. I've been looking for such a car but they are all selling before I can get there, people must be just buying them unseen...weird time. Nick
