3 members (JMD, DavidR, IcePack),
217
Topics49,899
Posts838,027
Posts: 51 Likes: 2
Posts: 51 Likes: 2 |
Just like to say thanks to the Speedy Marmots Journey Hanger work #18 sound proofing write up. I followed his steps and am very pleased with the improvement in bevel box noise reduction. ![[Linked Image]](https://www.tm-img.com/images/2021/04/26/IMG_E2942.jpg) Also I did not know there is a grease fitting on the U-joint under the center hump that I removed to add two layers of Dynamat.
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
Posts: 131 |
If you haven't already, adding Dynomat all the way up behind the seatbacks, then sealing the rear bulkhead seams with aluminum tape will help with road debris too. I went so far as to dynomat under the rear tray. Also the footwells, then applied CocoMat panels over it. Big difference.
'17 M3W (BRG) '03 Plus 8 35th Anniversary (BRG) '08 Ural Patrol (BRG) '21 Vespa 'Racing 60' (BRG)
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
There are two grease points on the prop shaft, one on each Universal Joint.
Posts: 492 Likes: 11
Posts: 492 Likes: 11 |
Question for both 2017 Betty and Javier, did you leave bottom panel gaps for possible water drainage in the event you get caught in a rain storm? Or did you button things up tight?
Craig - Texas, USA 2026 Plus Four 2021 M3W
Posts: 960 Likes: 21
Posts: 960 Likes: 21 |
In my case I didn't "folded up" the Dynamat pieces, so water can flow over them and meet the existing super thin gap between the chassis tubes and the floor steel plate. I mean I installed them flat on the floor and just getting a little bith under the chassis tubes, but I hope without clogging these thin gaps between the floor steel plate and the chassis tubes.
I still haven't drive under heavy rain (Madrid, Spain, where I live is really dry) so I can't tell you if the Dynamat is avoiding the water to flow out properly...
Posts: 51 Likes: 2
I did not fill in all the gaps with foam or metal tape. I was afraid it would fill up with water like a bath tub in the rain. Actually thought about adding some drain holes in the floor but changed my mind at the last min.
Thanks both for confirming. I don't plan on driving in the rain, but I live in Texas, so we occassionally have torrential down pours out of no where, so just wanted to be safe.
Posts: 1,016 Likes: 2
Posts: 1,016 Likes: 2 |
I did not fill in all the gaps with foam or metal tape. I was afraid it would fill up with water like a bath tub in the rain. Actually thought about adding some drain holes in the floor but changed my mind at the last min. My new 2020 chassis is mastic-sealed to the aluminium floor panels and it fills with water when we get caught in the rain. I have had to drill holes on the corners to let it drain. In a very wet Wales last year we had nearly an inch of slopping about water in the footwells, which didn't impress Mrs R1NGA very much (the mental scars will take a while to heal there I fear....)
