6 members (JMcL, SEG, BobtheTrain, Zach, MartO, CooperMan), 233 guests, and 22 robots.
+8Rich 96
John V6 51
Topics49,902
Posts838,049
Page 10 of 10 1 2 8 9 10
CBY Offline
The main aim of the SSL front kit is providing an adjutment of the suspension in order to avoid a compressed rebound spring at static height.
The standard configuration provides a great stiffness in the first travel step of compression due to the compressed rebound spring (adding the stiffnesses of the main spring and the rebound spring) when you need a small stiffness to absorb small bump and in a second travel step of compression the rebound spring is released providing a smaller stiffness for big bump when you need the opposite. The standard configuration works in an opposite way of a "normal designed" suspension.
Externaly the SSL front kit provides the same configuration with 2 springs but works in a normal way: soft of small bumps and increasing stiffness for great suspension travel. Externaly, if you look at wheel level you don't see any difference: there is two springs. Only at the top there is an adjustment device and inside a small spring (replacing the standard rubber silent block) providing an additionnal progressive stiffness at the end of the compression travel. The SSL front kit allows a normal work.
Having the SSL front kit, the front suspension of my 2005 PLUS 4 is more confortable and this is the best improvement I made.
Regards
2005 PLUS 4
mph Offline
Mines deffo a Trad, and left the factory with a 5 link rear ! Having done a couple of hundred miles in it this weekend it's blik'n marvellous
Does the front suspension have the SSL setup ?
mph #701713 03/05/21 10:36 AM
Yep, but I installed that, as I ran Suplex on the previous Roadster, but just couldn't justify what MMC wanted to charge as an option on a new build (no ££credit for the std springs & shocks they weren't fitting !)
