1 members (Mauli), 242 guests, and 41 robots.
John V6 71
DaveW 67
+8Rich 65
9,208 Registered Users
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Topics48,341
Posts812,981
RedThree
Page 3 of 4 1 2 3 4
miles of smiles
miles of smiles
Nice work as usual, Craig. I took the normal “Ewanist” approach and just sprayed the whole clump of rusty muck with satin black, works really well for at least a fortnight laugh2
Resurrection of this post. I noticed that my exhaust bobbins on my 2011 plus 4 are just showing signs of perish.
questions:
1. Can they be replaced without disconnecting exhaust pipes and silencer /manifold joints?
2. The L-shaped bracket that is bolted to the chassis: Are the bolts captive as the nuts are on the outside but the heads are not readily accessible.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
I replaced the 4 bobbins on my 4/4 without disturbing anything else.
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 5
Yes really easy to change, no need to disconnect exhaust pipes etc
Craig Jezz
Thanks for replies from two 4/4 owners, but it only answered my question 1. Not sure if it is the same arrangement as the +4.
The issue as I see it is that the bottom fixing of the bobbins is on a L shaped bracket that is bolted to the chassis. The top fixing is on a plate that shares a fixing with the silencer u- clamp.It looks to me that the only way of doing it is to remove the L bracket, but are the bolts that hold it, captive, or are they likely to either slip inside the chassis rail or when re- tightening, go round and round.
That’s really all I need to know.
Doug
1958 Triton 650
Deejay #761258 12/11/22 08:27 PM
There’s enough float and flex in the exhaust system to just under the bobbin nuts and lift the system off of them
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
The chassis fixings are captive
Many thanks Simon and Dave. Exactly what I hoped to hear.
Doug
1958 Triton 650
SimonH #761290 13/11/22 07:30 AM
and for extra ground clearance you can chop some of the thread off the lower stud which makes fitting them easier still.
DaveW #761295 13/11/22 08:31 AM
Well yes and no. They are formed of two studs welded to a plate and fitted from the inside of chassis, through holes drilled just behind rear cross member. If side pipes are spec'd on the 3.7 Roadster at least, the holes are drilled forward of rear chassis member to accommodate the shorter silencers. Unfortunately once all the trim, seats and belt fixings are in it's too onerous a task to move them I found.
Page 3 of 4 1 2 3 4
