Topics49,904
Posts838,075
Posts: 72 |
One of the lift the dot studs on the windscreen of my 2006 4/4 has snapped off, would I be correct in assuming that they are screwed in to the frame? If that is the case and I can remove the remaining portion where would you suggest I look for a replacement, I have looked at a few classic sites but not found anything that looks suitable.
Thanks
Chris
2006 4/4 70th Anniversary Edition 2004 3.2 Audi TT Quattro
Posts: 318 Likes: 5
Posts: 318 Likes: 5 |
Try Woolies-trim. I’ve just ordered some tonneau fixings from them for the half tonneau I’m making.
Posts: 504 Likes: 2
Posts: 504 Likes: 2 |
Google "lift the dot studs/fasteners" or the like. There are loads of retailers, for instance on ebay. I do not know how it it is fixed to the frame (I have the easy-up hood), but I suppose it is screwed, can't be much else. If the stud is broken completely flush with the frame it might be difficult to get it out, if there is a little remain it ought to have the shape of a nut so you can unscrew it with a little spanner.
Robbie the Norseman 2004 V6 Roadster Sherwood green
Posts: 1,625 Likes: 25
Posts: 1,625 Likes: 25 |
Posts: 37,481 Likes: 989
Posts: 37,481 Likes: 989 |
I have used Woolies they provide a good service.
Posts: 8,701 Likes: 501
Posts: 8,701 Likes: 501 |
Chris they are screwed, if it's bust off flush you can carefully Dremel a slot in the end and remove with a simple screwdriver
Be VERY careful of the thread length on the new stud or you'll be forking out for a new 'screen, compare it to the removed 'bit' and cut down
Posts: 504 Likes: 2
CooperMan is absolutely right. If the thread length is too long it will crack the screen when you tighten it.
Posts: 2,583 |
europa spares have them as do carbuilder solutions.
