2 members (DCH, sezznowt), 262 guests, and 37 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,147
#704582 25/05/21 04:04 PM
One of the lift the dot studs on the windscreen of my 2006 4/4 has snapped off, would I be correct in assuming that they are screwed in to the frame?
If that is the case and I can remove the remaining portion where would you suggest I look for a replacement, I have looked at a few classic sites but not found anything that looks suitable.
Thanks
Chris
2006 4/4 70th Anniversary Edition
2004 3.2 Audi TT Quattro
Try Woolies-trim. I’ve just ordered some tonneau fixings from them for the half tonneau I’m making.
Google "lift the dot studs/fasteners" or the like. There are loads of retailers, for instance on ebay. I do not know how it it is fixed to the frame (I have the easy-up hood), but I suppose it is screwed, can't be much else. If the stud is broken completely flush with the frame it might be difficult to get it out, if there is a little remain it ought to have the shape of a nut so you can unscrew it with a little spanner.
Robbie the Norseman
2004 V6 Roadster
Sherwood green
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
I have used Woolies they provide a good service.
Chris they are screwed, if it's bust off flush you can carefully Dremel a slot in the end and remove with a simple screwdriver
Be VERY careful of the thread length on the new stud or you'll be forking out for a new 'screen, compare it to the removed 'bit' and cut down
CooperMan is absolutely right. If the thread length is too long it will crack the screen when you tighten it.
Robbie the Norseman
2004 V6 Roadster
Sherwood green
europa spares have them as do carbuilder solutions.
