1 members (CraigL),
342
57
Topics49,897
Posts838,017
Posts: 17 |
1988 4/4 1.6L CVH with the smaller 28/32 Weber.
Upon starting off or just giving it the gas with the bonnet up, the motor bogs down before catching and moving on. If this were my TR powered +4 I would say the SU carbs need dashpot oil. finally have the ignition time corrected and new plugs. Rebuilt the Weber with a new accelerator pump, appears to be working all well.
Are there any adjustments I am missing?
Posts: 6,675 Likes: 441
Posts: 6,675 Likes: 441 |
Manual or electric fuel pump? Float height set right? Secondary idle jet blocked? Just initial thoughts......
Posts: 17 |
Manual fuel pump. Float height set correct at rebuild, no starvation at high RPM under acceleration loads so I don't think that's an issue. Need to check the idle jet, should be clear but........
Thanks, Bill
May be a lazy pump, when the engines on full chat it's providing enough juice, but at lower revs, may not be pumping enough?
Posts: 5,468 Likes: 172
Posts: 5,468 Likes: 172 |
Is it possible to transpose the jets when rebuilding?
The reason I ask is that my CVH engined car had similar symptoms after I swapped to a higher flow air filter than standard. The fix (by Mike Duncan) was to change the jets. I cannot remember any of the details now (15 years later).
Posts: 8,696 Likes: 416
Posts: 8,696 Likes: 416 |
Title suggests terminal aviation issue
Posts: 17 |
Problem Solved: It was the fuel passage between the pump and the venturi; reamed it clean with some wire and now all is good!
Posts: 27,838 Likes: 764
Posts: 27,838 Likes: 764 |
Posts: 1,031 Likes: 120
Posts: 1,031 Likes: 120 |
Maybe check the hose/s something is blocking things up. could be debris in the tank and or dodgy fuel filter more likely the rubber fuel hose and down to E10 fuel breaking it down.
