5 members (bmgermany, potty45, John V6, GrumpyPa, How), 261 guests, and 39 robots.
+8Rich 96
John V6 51
Topics49,899
Posts838,024
Page 3 of 3 1 2 3
In essence, you're right about the fuel pump wiring.
All the Omex sensors in effect operate on the earth side so they are live and the operation opens the earth link.
The process that controls the fuel pump also includes the crank speed sensor.
When you initially switch on the ignition the pump runs as you say to pressurise the fuel rail but after 2 seconds the ECU recognises that the engine is not cranking so switches the pump off again.
However when you then operate the starter and the engine cranks above a certain speed (I think about 200rpm but I could be wrong) the ECU recognises that you are trying to start the engine so the pump keeps running.
If you had a flat battery or duff starter and the engine did not reach the required cranking speed the fuel pump would not operate.
This also means that if for example the fuel line split or detached of course the engine would stop and the fuel pump would switch off to prevent fuel spraying everywhere.
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
Please let me know the source of the cheap vino
Just looked at my old OMEX notes and the minimum cranking speed is set at 50 rpm to recognise the start up condition not 200 rpm as I alluded to earlier.
How quickly we forget these things !!
Bob
2009 Black Roadster
ALDI ! that's one benefit of the COVID masks i can sneak in wearing a mask, wouldn't want the neighbours seeing me entering that retail outlet....they'd think we were on hard times🤗
Page 3 of 3 1 2 3
