2 members (Zach, flyfisher), 213 guests, and 79 robots.
+8Rich 64
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,880
Posts837,760
Im trying to find a replacement for a washer jet for a 1969 4/4. It has a screw either side on base plate. I have a photograph of original one if that helps.
Or would you know where I could source one from?
Also - The base plate that sits in the spare wheel that the T bar screws into please.
Thank you
Mandy
Mandy
There are a couple of washer jets on Holdens site.
https://www.holden.co.uk/c/hardware/washers_wipers/washer_jets_tubing_fittings
Mandy,
Another option for you.
TBM Offline
If it's the 'lozenge shaped base plate' I too struggled to find an exact fit (I'm assuming you have a twin wiper, single washer jet in the middle). I originally fitted a generic twin one on a home made plate, but was never happy with the angle of the jets, so I got a Jaguar one which covers the plate holes and works much better.
There is a spare wheel mount on ebay. Looks like a 'wire wheel' one that's been adapted to a disc wheel one. Should be easy to cut of the studs.
Wheel Mount
I would have thought the likes of Malvern Sheet Metal could make a spare wheel mounting plate - they make body panels smile
The gimballed washer jet assembly is a very rare part indeed.
Only other vehicle it was fitted to is the AC Cobra.
The last one that I saw on eBay went for very silly money indeed!
Arwyn
TBM Offline
This is the one I used, although can't find what model car it's off = I think it was an old classic Jag.
[quote=Arwyn Williams
Arwyn[/quote]
And I believe also seen on Daimler darts
They do come up on eBay from a chap in Bolton but as Arwyn says they are not cheap
X
X
As I was a Long time in classic MINIs…
A look is a lot of times interesting: (and cheap)
http://www.minispares.com/search/classic/washer%20jet.aspx
Greets René
2018 plus4 (sports green)
