11 members (bmgermany, MOG42, Strathaven, Clipper, JoeSpeetjens, gomog, MJF, RichardV6, John Winn, SailingTom2, uvk33n),
272
Topics49,911
Posts838,146
Posts: 423 Likes: 2
Posts: 423 Likes: 2 |
Hoping someone can help me. A friend of mine recently passed and I am helping his wife liquidate the rolling stock.
I have sold his 1932 JAP sport, but I need to know the sequence of starting one of these things. Would a appreciate it if any of you owners of these old three wheelers can give me a lesson. Crank start, no electric starter.
Thanks Lance
Lance 1981 Plus 8 2016 Three Wheeler 2022 Corvette Stingray Convertible z51
Posts: 1,149 Likes: 19
Posts: 1,149 Likes: 19 |
there is lots to think about before starting i counted 8 steps, first is to check oil and dry sump....
Morgans 1934 MX, 1947 Series 1, 1956 +4 TR4, 2000 +4 T16 Triumph Herald 1969 13/60 Morris 1970
Open sump plug and drain excess oil check oil feed to sump is it turned on? fuel on tickle carb to richen for starting (ensure you are not using stale fuel) fully retard the engine this is the lhs lever air valve closed this is the rhs lever same side as throttle throttle on a bit (if you are not fully retatrded then their will be a kick back on the starting handed and you risk damage to your wrist ensure your thumb is not in the way as the engine warms advance on timing air valve adjust for improved tick over check oil return to oil tank remove oil filler cap and you will see oil trickle out of return pipe
after running check colour of plugs are they oiled up? or chestnut colour?
Posts: 423 Likes: 2
Rob, Thanks you When you say air valve, are you referring to the choke? is there a compression relief on these?
Lance
Posts: 338 Likes: 1
Posts: 338 Likes: 1 |
It is not advisable to use a starting handle on the JAP. If you have to then you may get away with it once or so. Not on a regular basis though, damage will be caused to the gear teeth in the timing chest.If a valve lifter is fitted ( and there should be) and you must try to hand start it make sure it is fully retarded. Be warned this thing could break your wrist or arm easily and if it kicked back strip all the timing gear teeth as well. This is well known by owners like me.The Matchless engine is a completely different beast and will happily start on the handle but even then must be retarded. Ian Parkinson
Ian Morgan Family 1929 ( KTW 1100cc ) Morgan S/S 1934 Morgan F4 M3W 2012 Morgan +4 T 1991
Posts: 37,486 Likes: 993
Posts: 37,486 Likes: 993 |
Wow Ian that advise could well have saved Lance a major injury and expense, this place is a font of knowledge and experience.
Posts: 60 |
It may not be apparent to those used to starting smaller engines with a handle. that you will only turn the engine over a compression stroke on the UPstroke of the handle. i.e. turn the handle until compression is felt then adjust the handle if necessary to around the '7 O'clock' position. Be absolutely sure to keep your thumb on the same side of the handle as your fingers, and give it a smart upward pull. If the Mog has been unused for a while it may save a lot of time, energy and frustration to get someone to give it a bump start by pushing or towing it. Good luck.
Johnny Vans
Brooklands Edition M3W 1935 F2 2021 Mini Electric
Interesting about cranking engines over, it was a common way of starting cars in my youth, even if it had an electric starter you would turn it over once or twice to help it along in the winter, I still put the Plus 8 in 2nd gear and rock it a bit after a week of non running. Mind you swinging over and starting a Lister HA6 is a matter of strength and timing to hit the ganged decompression lever at the right time - happy days in RSA. I don’t imagine the new Plus4/6 owners would recognise one😉 a crank handle that is
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
It is not advisable to use a starting handle on the JAP. So if you can't crank them and they don't have electric start, does this mean you have to bump them to get them going?
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
I understand people have retro fitted a starter. the fellow at Shenandoah a couple of years ago had a starter added to his JAP. it was the red M3W
