11 members (TalkMorgan, hugo, RichB, Rex_tulips, Zach, RichardV6, RedThree, DaveK, howard, lez, IcePack),
303
40
Topics48,362
Posts813,332
Members9,215
Posts: 21,871 Likes: 168
Posts: 21,871 Likes: 168 |
I think somebody cut one up, and the part which takes the brake pressure had distorted, and broken the electrical connection.
A relay will help the current problem but a microswitch on the pedal is an easy fix.
Posts: 26,759 Likes: 424
Posts: 26,759 Likes: 424 |
Agreed Jon the new ones are rubbish
Posts: 35,790 Likes: 471
Posts: 35,790 Likes: 471 |
Part of the problem is the poor quality of OE replacements, that's why +8 Richard's originals are still working That is making the assumption that it wasn't replaced before I took custody of her 7 years ago Jon, as such it is an unknown but possible  .
Posts: 7,941 Likes: 218
Posts: 7,941 Likes: 218 |
My brake lights stay on intermittently, I give the switch a gentle tap then light goes out. Does anyone have a part # please? I believe these switches aren’t very reliable, as an alternative has anyone tried mounting a micro switch off the brake pedal? Here is the part you requested Dave. Slaving a relay will remove the current factor from the hydraulic switch as John suggests, this makes them far less prone to failure. I have never had a failure on either of my Plus 8's in about 50,000mls and 11 years to put things in perspective for you. I would recommend avoiding adding the complexity of a relay to this safety critical circuit which will increase potential for unreliability. As John V6 suggests his failed even with low current LED brake lights so better to source a quality replacement switch.
My brake lights stay on intermittently, I give the switch a gentle tap then light goes out. Does anyone have a part # please? I believe these switches aren’t very reliable, as an alternative has anyone tried mounting a micro switch off the brake pedal? Here is the part you requested Dave. Slaving a relay will remove the current factor from the hydraulic switch as John suggests, this makes them far less prone to failure. I have never had a failure on either of my Plus 8's in about 50,000mls and 11 years to put things in perspective for you. I would recommend avoiding adding the complexity of a relay to this safety critical circuit which will increase potential for unreliability. As John V6 suggests his failed even with low current LED brake lights so better to source a quality replacement switch. You pay your money and take your choices is how I view it with my experience with them and slaving relays is a very common practise. I had the pedal mounted micro switch fail on my 2009 4/4 Sport at 10,000mls so neither system is failsafe without getting carried away.
Posts: 463 |
I’m going to install a switch similar to the factory using the design from Geoffs Shed http://geoffsshed.net/mechanical_brake_light_switch.htmlAlready have LED lights but will also replace the PS with one made in USA. I would like to thank everyone for their help and encouragement this is what makes owning a Morgan so much fun. Cheers 🍺🍺
Dave 98 +8 Corsa Red 74 MGB Red
My brake lights stay on intermittently, I give the switch a gentle tap then light goes out. Does anyone have a part # please? I believe these switches aren’t very reliable, as an alternative has anyone tried mounting a micro switch off the brake pedal? Here is the part you requested Dave. Slaving a relay will remove the current factor from the hydraulic switch as John suggests, this makes them far less prone to failure. I have never had a failure on either of my Plus 8's in about 50,000mls and 11 years to put things in perspective for you. I would recommend avoiding adding the complexity of a relay to this safety critical circuit which will increase potential for unreliability. As John V6 suggests his failed even with low current LED brake lights so better to source a quality replacement switch. You pay your money and take your choices is how I view it with my experience with them and slaving relays is a very common practise. I had http://www.talkmorgan.com/ubbthread...nk-rear-suspension-re-visited#Post594455 pedal mounted micro switch fail on my 2009 4/4 Sport at 10,000mls so neither system is failsafe without getting carried away. With headlamp controls I would agree to save dipswitch contacts although less relevant to LED ones with their much reduced current draw. I can't recall any manufacturer that uses a relay in the brake switch circuit though and again LED conversions reduce contact burning issues to near zero. With electrics and maybe plumbing the KISS principle when possible seems to offer best reliability.
Posts: 7,910 Likes: 242
Posts: 7,910 Likes: 242 |
I found Intermotor brand to be ok, beware of modern Lucas stuff in white & green boxes, a considerable amount is very poor ROC copies
Posts: 528 |
My brake lights stay on intermittently, I give the switch a gentle tap then light goes out. Does anyone have a part # please? I believe these switches aren’t very reliable, as an alternative has anyone tried mounting a micro switch off the brake pedal? Here is the part you requested Dave. Slaving a relay will remove the current factor from the hydraulic switch as John suggests, this makes them far less prone to failure. I have never had a failure on either of my Plus 8's in about 50,000mls and 11 years to put things in perspective for you. I am resurrecting this thread because next week my car goes in for its MOT and I have just discovered that none of my three brake lights are working so I am assuming its the brake pressure switch. In quote Rich has quoted the replacement part for 1975 to 2005. My car is a Plus 4 first registered in Sept 2006. Anybody know the correct part number for 2006 on?
To test if it is the switch remove the leads and then connect a wire across the leads. With the ignition on the brake lights should be on. I would expect your switch to be as the 2004 car. You can if you are quick remove and replace the switch without needing to bleed the brakes.
