4 members (Sir Percival, MATTMOG, gomog, Hamwich), 220 guests, and 36 robots.
+8Rich 99
John V6 57
Topics49,909
Posts838,132
Page 2 of 6 1 2 3 4 5 6
John V6 #714156 14/08/21 06:59 AM
Originally Posted by John V6
Definitely clean the earth strap
2nd that after my recent fun with starting problems, cleaned up and tightened the Solenoid connections and she's running perfectly now.
Silver Morgan +8 " The Duchess"
'69 Triumph Bonneville
Life is a journey, best traveled in a Morgan
John V6 #714167 14/08/21 09:53 AM
Ian
I hope I am not preaching to the converted but does he realise there are 2 earth cables. One is the standard battery to the chassis (at the back of the car) , the other is the engine to the frame or something metal bolted to the frame (in the engine bay)
Andy G
1999 +8 , Indigo Blue.
meabh #714169 14/08/21 10:14 AM
I had similar a few years ago on a 4/4. I ran a long jump lead from the battery neg to the starter mounting bolt to bypass the existing earths. Car started ok so it showed a bad earth. I cleaned the straps ( battery to chassis and starter to chassis) and cured it.
A second possible problem could be a sticking solenoid. Newer cars have one on the motor body itself rather than remote. Tapping it carefully with a wooden rod can free it. You then either get it cleaned up to stop sticking ( also check the wiring) or carry a stick! I did this years ago for a couple of days until I could clean the solenoid/motor.
meabh #714173 14/08/21 10:27 AM
With mine I just ran the jumper from the engine to the cross head tie bar to show up the poor earth
meabh #714222 14/08/21 03:56 PM
meabh Offline OP
John,Sospan, Andy, et al, Thank you for all your replies. So far this remains a mystery and its so frustrating when you have a friend that you can't help, especially when they are in a different country as well. You all remain a positive helpline and when we discover what this is all about I'll let you know. I remember well, when my own 89 P4 stopped working and a good three weeks went by before I had one of those light bulb moments and rechecked a relay. It was so simple. Perhaps this will turn out to be the same. Thank you all.
meabh #714244 14/08/21 05:30 PM
Does that era of Plus 4 have the immobiliser ring problem that some have encountered ?
meabh #714291 14/08/21 08:22 PM
meabh Offline OP
I can't remember now whether it is a 05 or 07 car and my friend is out of contact at the moment. Last I heard he couldn't find the relays. Does anyone have a similar car and point me in the right direction?
meabh #714301 14/08/21 09:22 PM
Hi meabh,
My car's a 4/4 2006 build but I'm sure the p4 relays are in a similar position as mine......
....behind the dash, high up, just left of the steering column when looking forward. Use a mirror to see them. Unless slim wristed and mobile detach the dash to change.
Hope this helps.
Regards
Geof
70th Anniversary 4/4 (Duratec 1.8), model 1995
meabh #714302 14/08/21 09:26 PM
meabh #714303 14/08/21 09:34 PM
meabh Offline OP
Salmo and Mr W Thank you
