7 members (hillclimber, AlyMatt, Luddite, DaveW, Jeff D, lez, Biggle),
126
40
Topics49,911
Posts838,138
Posts: 59 |
Definitely clean the earth strap 2nd that after my recent fun with starting problems, cleaned up and tightened the Solenoid connections and she's running perfectly now.
Silver Morgan +8 " The Duchess" '69 Triumph Bonneville
Life is a journey, best traveled in a Morgan
Posts: 2,272 Likes: 7
Posts: 2,272 Likes: 7 |
Definitely clean the earth strap Ian I hope I am not preaching to the converted but does he realise there are 2 earth cables. One is the standard battery to the chassis (at the back of the car) , the other is the engine to the frame or something metal bolted to the frame (in the engine bay)
Posts: 9,554 Likes: 134
Posts: 9,554 Likes: 134 |
I had similar a few years ago on a 4/4. I ran a long jump lead from the battery neg to the starter mounting bolt to bypass the existing earths. Car started ok so it showed a bad earth. I cleaned the straps ( battery to chassis and starter to chassis) and cured it. A second possible problem could be a sticking solenoid. Newer cars have one on the motor body itself rather than remote. Tapping it carefully with a wooden rod can free it. You then either get it cleaned up to stop sticking ( also check the wiring) or carry a stick! I did this years ago for a couple of days until I could clean the solenoid/motor.
Posts: 27,846 Likes: 764
Posts: 27,846 Likes: 764 |
With mine I just ran the jumper from the engine to the cross head tie bar to show up the poor earth
Posts: 2,290 Likes: 9
Posts: 2,290 Likes: 9 |
John,Sospan, Andy, et al, Thank you for all your replies. So far this remains a mystery and its so frustrating when you have a friend that you can't help, especially when they are in a different country as well. You all remain a positive helpline and when we discover what this is all about I'll let you know. I remember well, when my own 89 P4 stopped working and a good three weeks went by before I had one of those light bulb moments and rechecked a relay. It was so simple. Perhaps this will turn out to be the same. Thank you all.
Posts: 8,701 Likes: 501
Posts: 8,701 Likes: 501 |
Does that era of Plus 4 have the immobiliser ring problem that some have encountered ?
I can't remember now whether it is a 05 or 07 car and my friend is out of contact at the moment. Last I heard he couldn't find the relays. Does anyone have a similar car and point me in the right direction?
Posts: 383 Likes: 6
Posts: 383 Likes: 6 |
Hi meabh,
My car's a 4/4 2006 build but I'm sure the p4 relays are in a similar position as mine...... ....behind the dash, high up, just left of the steering column when looking forward. Use a mirror to see them. Unless slim wristed and mobile detach the dash to change.
Hope this helps.
Regards
Geof 70th Anniversary 4/4 (Duratec 1.8), model 1995
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
