0 members (),
292
Topics49,904
Posts838,088
Posts: 1,544 Likes: 1
Posts: 1,544 Likes: 1 |
I was assured at RTCC today they are dual circuit......
Posts: 1,112 Likes: 17
Posts: 1,112 Likes: 17 |
Is there a stainless option for the rear brake cylinders now? Think a rear one might of seized after about 4 years and was wondering if there is any better options now…
Posts: 37,484 Likes: 989
Posts: 37,484 Likes: 989 |
There is a company that will put you a stainless sleeve in them, it's on here somewhere, I just replace the fluid regularly and renew the cylinders when necessary it's a simple enough job and the cylinders are cheap too.
Posts: 786 Likes: 18
Posts: 786 Likes: 18 |
Exactly the stainless steel sleeve saves old cars whose parts do not exist.
Posts: 1,738 Likes: 56
Posts: 1,738 Likes: 56 |
Past Parts will refurbish old brake cylinders with stainless sleeves. I did get a quote from them but it seemed fearfully expensive to me. In the end, I decided just to use some red brake grease to keep the corrosion at bay. Edit - I've just looked up the quote and actually it was £60 + VAT + shipping which I guess isn't too bad in retrospect. Problem is that you can get brand new ones off eBay for nearer to £10 all in.
Andy
Ok might just stick with the standard.
Many thanks
Posts: 8,701 Likes: 501
Posts: 8,701 Likes: 501 |
Past Parts as per Andy's link above are very good & turn work around in sensible timescales, excellent for brake components that are no longer available
