7 members (Tony Quinn, JohnHarris, MOG42, JoeSpeetjens, Strathaven, RichardV6, bmgermany), 237 guests, and 31 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,146
#717175 07/09/21 04:32 PM
Hi
I'm trying to find a tuner with a rolling road in NE England who has the gear to get into a 14cux hotwire brain. There are plenty of remap guys with rolling roads but only access OBD2 brains.
Any advice or recommendations will be most welcome
Cheers
Alan
1999 Morgan Plus 8. 3.9 ....
1961 Alvis TD21 Series1 3 Litre Auto....
I used to recommend I & J Macdonald in Lanchester , but they closed and the business was taken over by Beamish Morgans. Within the last year/s or so their chief mechanic (ex Macdonald) has set up on his own.
I don't have his details but I am sure that there are others here who do , his name is Peter Davison. Not sure if he has a rolling road any more.
Outside of that, and I know it is a bit outside your NE area, the only outfit I would recommend is Mark Adams near Shrewsbury (who designed the Tornado chip) for the 14CUX. https://www.tornadosystems.com. He is the absolute authority on these engines and will get the very best he can from yours.
You could do a lot worse than just purchase a Tornado fuel chip for the 14CUX ecu and fit it yourself.
From experience the chip works best when you have a free flowing exhaust manifold, (Librands or similar) and a less restricted air filter than the standard black cannister.
Andy G
1999 +8 , Indigo Blue.
Hi, John Mcdonald left his rolling Road behind when he moved to Beamish Morgan, I don't think Peter will have got around to installing one yet as with any new business he'll probably have other priorities - I might give him a call to see if he can point me in the right direction though.
My car has all the bits on and last time it was on the RR it was a tad under 250bhp, but it just scraped through th e MOT today. So I need to find out if its the cats or lambda sensors on the way out - or something else, then once it's sorted & I know where state of tune is, I want to change the injectors for BOSCH 4 port ones
Thanks for taking the time to reply
I changed mine for bosch 4 years ago, it is a cleaner burn (I think) when it was on the rolling road it made 281 bhp and over 300ib/ft, there was a bit of head work and 4.8 cc.
something I found out was that this engine really needs negative pressure in the crankcase, a small vacuum leak can cause the eco to enrich the mixture and make the CO reading high.
David Byrne
I was also thinking about changing to the Bosch 4 port injectors. I got a set of reconditioned units sitting ready , but I think I will delay fitting them until I have the car up with Mark Adams , as I expect it will need some adjustments to the fuel mapping.
Andy G
Originally Posted by smudger1
Hi
Cheers
Alan
Try BTG performance, based on the Tyne tunnel industrial estate. They might be able to help you out.
2004 Series 1 Roadster
