6 members (Ian Wegg, +8Rich, Hamwich, Alan Patterson, CBY, sprinty), 206 guests, and 46 robots.
Luddite 50
Posts837,948
#718415 17/09/21 05:07 PM
GLLOQ Offline OP
rubbing wear of the wiring harness behind the dashboard
Wrap the individual damaged sections with self amalgamating tape, then over-wrap the unprotected section with something to protect it, like ordinary tape that can be removed if you have to access individual cables later, and perhaps use cable ties to carefully pull it out of contact with the area rubbing
Just be aware self amalg tape bonds to itself very strongly - so don't over-wrap bunches of wires you need access too
Or use a wrap protector like spiral wrap, it is easily removed in the future.
miles of smiles
miles of smiles
Sealey does proper fleece tape; looks ace, or try their silicone self amalgamating tape; cleaner than rubber.
https://www.sealey.co.uk/product/5637188917/19mm-x-15m-fleece-tape---black
https://www.sealey.co.uk/product/5637201956/5m-red-silicone-repair-tape
Can recommend the self amalgamating silicone tape that Ewan linked to. Used it to great effect below on long range WiFi transceiver connectors on a sea going boat. Much cleaner to use than the black stuff.
