4 members (Nickplus4, Pittsartist, Tresco, John Winn), 269 guests, and 32 robots.
+8Rich 94
John V6 50
Posts837,997
rockabilly john
O
O
The easy bit is taking out the bolts and removing and installing the barrels, the hard part is getting the bolts back in. Thats when a big hole is an advantage especially if you have a big hand if you get what I mean.
Sounds good to me, turning the engine over to access the the next insert can be done in other ways.
Yes, I find it easier to remove the cam pulley cover and use a socket on the crank pulley bolt to rotate the engine.
Andy
That is a good way, but in my case I have a 4 post lift and can jack up the rear wheel and turn it by hand with the trans in gear to turn the motor (with plugs out).
Certainly easier when home and on a lift but on the road a different story.
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
Yes, but it is so easy to check them before a road trip, or on a weekly basis, that doing the mod really makes sense for me. And in my case I got lucky, one roler had almost completely fIled.
