6 members (GrumpyPa, JohnHarris, James B W, +8Rich, thelastgizmo, Paulxj), 236 guests, and 40 robots.
+8Rich 94
John V6 49
Posts837,993
rockabilly john
Page 5 of 10 1 2 3 4 5 6 7 9 10
Malcolm, are these pictures from Wilson any help to you in identifying an unmodified pedal.
As you will read MMC sent him the modified part and he fitted it himself as he and the car reside in France mostly.
Unmodified original brake pedal
New upgraded part
Brake modification as fitted
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
Pleased to report my pedal looks to have the modification already fitted. It looks like the bottom of those three pictures. Thanks for your help!
So are pics of the new car coming or wot? smile
92 Connaught Green Plus 4
Triumph Bonneville 865
Looking at the attachment manager it says only files below 1000 bytes can be added,. I don't know how to get my photos down to that file size!
What you need to do is reduce the image size (number of pixels). How, depends on the photo-editing software you use. I use an elderly Olympus digital camera (rather than a phone), and in my case right-click on the saved image you want to "Re-size" and select from Small Medium Large or Custom. The screen photos show an example of that.
Went to Forum help and it says the following;
In order to add an image to your message or your signature, you must have the image already available on a web server and reachable by a URL. This can be an image on your own personal web page, for example. To place an image within a message, simply use the following Markup Tag:
For example, if you have an image called cateye.gif and its available from your own website at http://www.example.com/pics, then you would use the following image markup:
You can do the same for your signature. Click the My Home option found on any page. Then, under the Your Profile group, click on "Edit Profile". Look for the Signature box, and enter your desired information, including any images/markup as above.
Note: To keep the forums loading quickly for everyone, it is recommended that you do not exceed 35k for your image size.
I don't have a private web page or pictures stored on a server so therein lies my issue!
TBM Offline
Grab yourself a TM Img account - free and makes uploading photos really easy.
TM IMG
TM IMG
Sort of.
TBM Offline
TM IMG
Sort of.
Ok. I should have said, as a 52 yr old History Teacher who's more comfortable with spanners than technology, I find it easy smile smile
