Topics49,901
Posts838,042
Posts: 32 Likes: 1
Posts: 32 Likes: 1 |
I could not think of another description for the " Drivers footwell cross bar". Its the bar, that is actually on the floor of both footwells, part of the frame, that I and probably many of you use to heave yourself out with. I put my feet on it and push myself up and then nip over the side. Hopefully you now no what I'm talking about. The aforementioned crossbar is now showing signs of wear and needs repainting. Does anyone have a recomended hard wearing paint that they may have used to do the same job? Thanks
M3W, Bentley Continental 6.0 Flying Spur, MGB BGT. Beetle Conv, Merc Est, Renault Cleo.
Posts: 39 |
I know exactly where you mean, and what you mean. I use black tank tape or gaffer tape to cover the tube, when in place it is difficult to see that it is not painted. The tape can be changed as often as needed ( it seems pretty tough and lasts quite well) with little effort or expense.
Hope this helps.
Posts: 423 Likes: 2
Posts: 423 Likes: 2 |
I use black traction tape so that I don't slip getting in or out.
Lance 1981 Plus 8 2016 Three Wheeler 2022 Corvette Stingray Convertible z51
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
I use black traction tape so that I don't slip getting in or out. Good idea. Stair tread tape, skateboard tape, etc. I put a wide strip of it on the third rail on my 4 post lift to stop the rear wheel from spinning on the aluminum channel. The tape covers between the upright legs of the channel. ![[Linked Image]](https://www.tm-img.com/images/2021/10/23/A118D460-1FC5-494F-999C-B08711F31F27.jpg) ![[Linked Image]](https://www.tm-img.com/images/2021/10/23/037B542B-F9DA-4F37-AC7A-972D483A3744.jpg) It also makes for good gripping surface on things you don't want to drop.
Posts: 125 Likes: 3
Posts: 125 Likes: 3 |
I have thought about the non slip tape as seen on skateboards, I think alluded to above. Not done it yet though!
I have thought about the non slip tape as seen on skateboards, I think alluded to above. Not done it yet though! ![[Linked Image]](https://www.tm-img.com/images/2021/10/23/037B542B-F9DA-4F37-AC7A-972D483A3744.jpg)
Posts: 46 |
Courtesy of Mr Bleazey The Special has a non-slip finish to the cross rail and it works a treat. I’ve no idea how he did it but it is certainly a good mod to do.
The Bleazey Special.
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
I painted mine with Hammerite which worked well.
Mix some sand in it to give an anti slip finish
Red Leader
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
Black plastic water pipe with a cut along the side so that it clips over the chassis tube works well. ![[Linked Image]](https://www.tm-img.com/images/2021/10/24/IMG_1730.jpg)
